Drum Sander?
  • RickT
    • Jun 2003
    • 175
    Drum Sander?
    I've been thinking about getting a drum sander, and I like the Performax/Jet 22-44. Is anyone using one? Which one? What do you like about it? Does it accurately and smoothly flatten stock? I'm planning to sand cabinet pieces (face frames, rails, stiles, panels). Thanks for any input.
    Thanks,
    Rick
    I have the discontinued Ryobi unit. Rarely do a project that isn't all plythat it doesn't see use.
    • Jim Boyd
      • 1766
      • Montgomery, Texas, USA.
      • Delta Unisaw
      I have the 16-32. If you set it up correctly, which is easy IMHO, they work well.
        The 22-44 is on the top of my wish list, I've used one, and it's pretty darned cool. I want one for truing glue-ups and for veneer sanding.
        I think you'd be happy with it, so long as you realize that you are taking light passes and 2-3 passes per depth.
        • tkarlmann
          • 360
          • Hoffman Estates, IL, USA.
          Seen the plans in Shop Notes?
          Current issue has plans for a shop-built unit powered by your table saw's motor. Unit also has a hand crank and a conveyor belt.
          Comments?
          Thom
            Just got the Performax 10-20 and wish I had done this years ago. I can see that what Pappy says is true, it will be used on every project.
            ken
            • RodKirby
              • 3136
              • Mao Shan TSC-10RAS
              Mine is only about a month old (Taiwanese), but WOW, this thing is going to be used all the time
              I also bought one of each grade of sandpaper "belt" - quite easy to wrap around the drum. 120 grit seems to be right for me.
              Very precise (flat) results and you can sneak up on the thickness you want.
              If I hadn't seen David Marks using one all the time, I don't think I would have even considered buying one.
              Downunder ... 1" = 25.4mm
              • Tundra_Man
                • 1589
                • Sioux Falls, SD, USA.
                I've got the Performax 10-20. Alignment was horrible out of the box, and the instructions were only one step above Harbor Freights. Once I finally got everything set up and adjusted, however, it's a good running machine.
                Terry
                • RickT
                  • Jun 2003
                  • 175
                  Thanks, guys, for all the great feedback. I've been thinking about a drum sander for quite awhile, and seeing David Marks use one all the time made me think about it more seriously. I think I'm on the right track, because I want to flatten glue-ups and sneak up on exact thicknesses.
                  Thanks so much,
                  Rick
