New to the bt3100
  • doncook7
    • 24
    • Berkley, MI. (just a few miles north of detroit)
    New to the bt3100
    Hi there. I just wanted to take a minute and say hello. I just bought the following from HD with a 20% off legit coupon....
    Ryobi BT3100 Saw system ....249.00
    Ryobi AP1300 Planer...199.00
    Ryobi TS1551DXL Compound Mitre Saw....219.00
    MINUS 20%
    = $533 and some change... + tax.
    I think i did ok.... :-)
    Some background info...
    1989-1991 apprenticed under a mennonite woodworker from PA, who apprenticed uder a mennonite "old timer", again from PA. I was 18-20 during that time. (35 now)
    First "i did it all on my own" - from picture, to scaling project - (round, mahogany, 24 scallops, 12 inch turned base, hand planed, hand oiled...etc...etc) sold for a few thousand dollars.
    Got out of it after deciding to go to college, away from home. (that, and about the same time ran my index finger over a jointer...sans guard....actually a good thing, since had the guard been on, I have no doubt my fingers would have faired worse... skin graffs took care of that...took some time to get back in the saddle i guess) Still would recommend using a guard! This mishap was just a fluke. Trust me.
    Went on to become a successful TV Director/Technical Director in Detroit.
    Have now decided to return to my roots....
    Looking forward to creating again...still work at the tv station... but looking to move on to what I love.
    Came across this forum, and look forward to being here more. Still looking to get a new router and jointer, as well as an economical DC system.
    Thanks for listening/reading....happy woodworking!
    Don
  • Ken Weaver
    • 2417
    • Clemson, SC, USA
    • Rigid TS3650
    Welcome Don! Watch for gmack's post of helpful tips. I think you'll enjoy getting back into things and you got some good stuff to get you started. Have fun, make sawdust and be safe!
    Ken Weaver
    Clemson, SC
    • Raymonator
      • 158
      • Near Ottawa Ontario
      From one newbie to another, welcome aboard Don. I wish I were living in the states right now, hard to believe you can get a Ryobi BT3100 for $249.00 ($400.00 here in Canada) I haven't purchased my BT3100 yet, but it won't be long I can assure you. Just waiting for the weater to warm up a bit.
      I think it's great that you had the privilege to learn from the mennonites, as they do things the old fashion way, but do it very well. I think anyone who doesn't know anything about wook working could learn a lot in a mennoite 101 wood shop course. Good luck with all your new toys, and hopefully we'll bump into each other here on the forum and share some ideas.
      Later
      Ray
      Measure twice....cut once.
      Happiness makes up in height what it lacks in length (Robert Frost)
      • monte
        ***** Windbag
        • 5242
        • Paw Paw, MI, USA.
        • GI 50-185M
        Welcome to the group Don. Be safe and enjoy your new tools.
        Monte (another darksider)
          Welcome to the Asylum, Don!
          • gfrenzel
            • 51
            • Sulphur, LA, USA.
            Welcome Don. You'll enjoy your BT3100 and also this site. Have fun.
            Garth
            HE took my nails. <><
            • gmack5
              • 1972
              • Quapaw, Oklahoma, USA.
              • Ryobi BT3000SX & BT3100
              Welcome Aboard!
              Welcome Don,
              Congratulations on the acquisition of your BT3100 and welcome to the "family".
              One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
              Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes.
              The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
              If you put it in one place, eventually it will be all over the entire saw.
              Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
              You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/index.php?page=articles
              The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site).
              One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
              This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM.
              Performing this PM on a monthly basis would be a good idea.
              One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
              A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30-60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner.
              That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
              Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
              You might also want to check out the "FAQ" in a "sticky" in the Getting Started Forum:
              http://www.bt3central.com/showthread.php?t=1699
              It'll answer a lot of your questions.
              George
              • doncook7
                • 24
                dead link...
                Thanks to all who've welcomed me! Just a quick question to gmack5...
                Is there any other place to get the "quick checklist"? The link seems to be dead, and i can't seem to find it.
                Again, thanks.
                don
                  Welcome aboard.
                  • RmeDad
                    • 231
                    • Scottsdale, AZ
                    Check List Location
                    Again, thanks.
                    don
                    Go here http://www.bt3central.com/index.php?page=articles and look under BT3 Maintenance & Repair.
                    WELCOME ABOARD!
                    Jack
                    Throughout my racing career I was constantly reminded of this: "Keep the pointy end forward and the shiny side up!"
                    • doncook7
                      • 24
                      staring me right in the face....
                      Thank you! I have a looked at the page several times and somehow read right over that...
                      I'll catch on.
                      Thanks again,
                      don
                      • gmack5
                        • 1972
                        Again, thanks.don
                        Don,
                        If you hadn't blocked "recieving" Emails, you'd have the information that you wanted by now.
                        I have a copy of the file (PM checklist) that you'd like to have but as things stand, I have no way to get it to you.
                        Since "Emails" from this forum are only sent between members (normally), blocking Emails is not very smart.
                        Sorry, my link was screwed up! Try this one instead.
                        George
                        • doncook7
                          • 24
                          my apologies...
                          I have to say i'm sorry. I didn't realize I was blocking emails. I am now on my way to find change that setting. I didn't know it was a default setting.
                          Thank you!
                          don
