Can Laminate flooring or engineered flooring glues be used for other purposes? They got some at my local Lowes for 0.50 for a half gallon can of either. I don't plan on doing any flooring in the near future and just wonder if I could use this for something else at that price.
Laminate flooring and engineered flooring glue?
"Reality is merely an illusion, albeit a very persistent one." by Albert EinsteinTags: None -
Hi M&M:
I would think it would be fine especially for gluing up sheets of MDF for workbench tops or particle board, you know building up thick panels from thin panels... I agree for the price you can't go wrong. I"m going to check out my Lowes to see if they are getting rid of it as well.
WEGComment
I do primarily lathe work and I use at least a gallon a year.Originally posted by vakingI remember reading somewhere that regular wood glue has a one year shelf life. How many galons of glue do you go through in a year?
Jim in Texas and Sicko Ryobi Cult Member ©Comment
Thanks for the replies. I'll have to go get a can or two before it's gone.
Does that shelf life thing apply to unopened glue or just open glue?"Reality is merely an illusion, albeit a very persistent one." by Albert EinsteinComment
mmmmm
Originally posted by MoldnMakerThanks for the replies. I'll have to go get a can or two before it's gone.
that refers to time from manufacture date. if you store it properly you may extend that a little bit. store it improperly and you can cut it down considerably.
FWIW: most glues such as titebond I and II have a 2 year shelf life. when you consider the cost of hardware, wood, the new tool for the job, sandpaper, time not spent fishing and finishing supplies--even 10 to 15 bucks for a bottle of glue that will last a number of projects is a steal.
robComment
