New BT3100
  • Shipwreck
    • Mar 2005
    • 85
    New BT3100
    A couple of you might remember me asking last year about getting back into WoodWorking. Well, .......... I did not buy the BT3100. I bought the Craftsman Zipcode saw........22114. Well, life got in the way and It ended up sitting in the crate until a few weeks back and I finally put it together. The size of the saw took up WAY too much space and it was finally carted away by a new HAPPY owner. I gave him a sweet deal on it.
    Went to the BORG and put the money down for the BT3100 yesterday.
    The box it was in, was kind of beat up and torn, but it was the last one. I told the manager that I would check it out before assembly and if there was any damage, I would make sure it was still packed right before I brought it back. He was very supportive about everything and told me that he would have a saw delivered to the store from another store if it was.
    Luckily for me, every thing was in its place and well packed. I assembled the saw, and was taking mental notes of the quality as I went along. I was impressed by the engineering that went into this machine,and the finish is very good!
    This morning, I'm going back out to the garage to assemble a mobile base for it, and go through all the adjustments on the saw.
    My impressions so far,.... tell me this is a very nice machine for the $249.00 that I paid for it.
    Congrats, you will love your new BT. It's a fine tablesaw.
    Get the 'Bug' out of the shop yet? ;-D
    ken
    • monte
      ***** Windbag
      • 5242
      • Paw Paw, MI, USA.
      • GI 50-185M
      Take your time and get everything adjusted properly. Enjoy your new saw.
      Monte (another darksider)
        The only preference most have for the 3000 over the 3100 is the base, and it looks like you are eliminating that. Assuming you have a saw with a new blade (made in China) that may require an upgrade.
        • gmack5
          • 1972
          • Quapaw, Oklahoma, USA.
          • Ryobi BT3000SX & BT3100
          WELCOME, Shipwreck!
          Welcome,
          Congratulations on the acquisition of your BT3100 and welcome to the "family".
          One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
          Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes.
          The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
          If you put it in one place, eventually it will be all over the entire saw.
          Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
          You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/index.php?page=articles
          The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site). One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
          This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea. One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
          A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner.
          That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
          Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
          You might also want to check out the "FAQ" in a "sticky" in the Getting Started Forum:
          http://www.bt3central.com/showthread.php?t=1699
          It'll answer a lot of your questions.
          Some of the links referenced in this post are not operational right now. We've got Brand-new software running the Forum and it's not totally "on-line" yet, just be patient and it will be before long.
          George
          • gmack5
            • 1972
            WELCOME, Shipwreck!
            Welcome,
            You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/ The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site). One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
            You might also want to check out the "FAQ" shown in the top of the Main Page, in the Wooden Bar across the Top
            http://www.bt3central.com/forum/topi...TOPIC_ID=12490
            George
