Hi,
I came across this jig from the simple clamp cabinet post earlier today. I understand what he is doing, however, from what I read it seems is it better to cut both pieces of the joint together. If I wanted to do what steps should I take. I have tried a coulple times with no sucess. What I want is 1/4" "fingers" for the joint, so I off set the two pieces a 1/4" and then go ahead and make some passes following his techniques, I am being pretty careful however nothing seems to be lining up. Any suggestions?
http://woodworking.phruksawan.com/boxJointJig/
thanks,
thanks,
