new guy with nine fingers
  • 1index only
    • 39
    Hi all name is Bill and yep you got it! only nine I got a used bt3k and was using it improperly obviously when I pushed my right hand directly into blade. Two cuts to the thumb and an index finger split down the center, literally made two out of one! well it didn't heal up correctly so back in Dec had the doc lopp it off inside the hand, no longer have an index finger at all. Oh well its not too bad, I can still write with it and do most everything else. I foung this site looking for a pair of rails cause mine are gone, figured I say HI!
  • MBG
    • Apr 2003
    • 945
    • Chicago, Illinois.
    Sorry to hear of your injury, but, please change you user name (I'll cringe every time I see it).
    • 1index only
      • 39
      figured it fit
      • 91FE
        • 303
        • Philadelphia (actually Souderton), PA.
        WOW
        I like Wagoneers too. Hey...they've got wood
          Welcome to the Asylum, Bill! You should fit right in!
          • ddamoore
            • Jun 2003
            • 225
            • Oklahoma City, OK, USA.
            • Craftsman (Ridgid 3612 Clone)
            Welcome aboard Bill.
            Seems to me there are a few posts about a red line around in here somewhere...oh wait...sorry, to late for that.
            (Sorry, couldn't resist)
            Dennis
            "Everybody is ignorant, only on different subjects" - Will Rogers
            • Otter
              • 865
              • Cumming, GA, USA.
              • Delta Left Tilt UniSaw
              Welcome, welcome....try to keep the rest of the digits.
              T.E. Lawrence
                Welcome aboard!
                • axio
                  • 459
                  • Castro Valley, CA, USA.
                  Whoa, sorry to hear that. I hope you keep the rest of em.... look into a Sharkguard, best $100 you could ever spend. Seriously.
                  • lcm1947
                    • 1490
                    • Austin, Texas
                    • BT 3100-1
                    Man, that's a bad deal. Sorry to hear it happened to you or anybody for that matter. Man! Anyway, welcome to the forum and may that be the worst you ever have to experience in this life time. Take care and be seeing you around.
                    • oldninefingers
                      • 40
                      • Patriot, Indiana, USA.
                      well my wife calls me "oldninefingers"
                      when ever I head off to the shop as a joke...I think... I do still have all ten digits
                      Tod
                      • jdschulteis
                        • 139
                        • Muskego, Wisconsin, USA.
                        Hi Bill! Sorry about your finger, glad you're getting on without it. You must love woodworking to be sticking with it. I have a coworker who quit the hobby--he mauled his left index and middle fingers, best the docs could do was attach the middle finger tip to the index stub, leaving him with a middle stub and a short index finger.
                        So, we know about your finger. What happened to your rails?
                        Jerry
                        Jerry
                        • jgrobler
                          • 259
                          • Salinas, CA, USA.
                          • TS3650
                          How would a Sharkguard prevent this, as opposed to the standard guard?
                          • gmack5
                            • 1972
                            • Quapaw, Oklahoma, USA.
                            • Ryobi BT3000SX & BT3100
                            Congratulations on the acquisition of your BT3100 and welcome to the "family".
                            One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
                            Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes. The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
                            Silicones repell liquid, making "fish eyes" in your finishes, this will force you to remove the Silicones from your project and start over. That stuff (Silicone) migrates all over every where, don't ask me how, it just does. If you put it in one place, eventually it will be all over the entire saw.
                            Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
                            A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
                            Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
                            George
                            • monte
                              ***** Windbag
                              • 5242
                              • Paw Paw, MI, USA.
                              • GI 50-185M
                              Welcome to the group.
                              Monte (another darksider)
