BT3100 Table flatness?
  • kw
    • 29
    • Vero Beach, FL, USA.
    Hi All,
    I just picked up my BT3100 at HD yesterday and started assembly...now I have some questions.
    #1- How flat are your tables? The miter table seems to be as flat as my straight edge; however the main table seems to dip slightly (i can just slide a sheet of paper under the straight edge).
    Also, the straight edge will rock slightly on the accessory table...again about the thickness of a sheet of standard printer paper.
    #2- There seems to be slight movement at the rear of the accessory table where the 2 tabs slide into the rail.... the left rear corner will move up and down slightly.
    So are these normal tolerances for the BT3100 (am I just paranoid) or should I be worried?
    Thanks,
    kw
  • thestinker
    • Oct 2005
    • 613
    • Fort Worth, TX, USA.
    I don't think that those kind of gaps would make a difference. At least not to my wood working ablilites. I would think that the rip fence being off or the SMT travel being crooked would have more of an impact on your cuts being square and true.
