Couldn't wait any longer
  • VillageNut
    • 17
    • Hot Springs, AR, USA.
    All the great talk about the bt3100 on here was more than I could stand. Purchased my new saw at BORG Friday and assembled and aligned it today. Just waiting on good weather to complete my shop and will be ready to make some dust....
    One question. Where is the best place to obtain the extensions...
  • Wood_workur
    • 1914
    • Ohio
    • Ryobi bt3100-1
    Welcome! Have fun, be safe, and paint the red line. The best (and probably cheapest) place to get rail extensions is in the Member classified section if you can wait for a week or two.
    Alex
    • gmack5
      • 1972
      • Quapaw, Oklahoma, USA.
      • Ryobi BT3000SX & BT3100
      Welcome Kelly,
      I was getting tired of waiting too!
      Congratulations on the acquisition of your BT3100 and welcome to the "family".
      One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
      The Illustration shown below is of a BT3000SX.
      Most of the accessories shown will also fit the BT3100.
      Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes. The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
      entire saw.
      Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
      You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/ The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site). One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
      This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea. One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
      A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
      Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
      You might also want to check out the "FAQ" shown in the link below.
      http://www.bt3central.com/forum/topi...TOPIC_ID=12490
      It'll answer a lot of your questions.
      George
      • Ken Weaver
        • 2417
        • Clemson, SC, USA
        • Rigid TS3650
        Welcome aboard Kelly.
        Ken Weaver
        Clemson, SC
          I got my extensions with another forum member from Order Tree.
          Welcome and have fun.
          • monte
            ***** Windbag
            • 5242
            • Paw Paw, MI, USA.
            • GI 50-185M
            Welcome to the group Kelly. Enjoy your new saw.
            Monte (another darksider)
            • silverfox
              • 2863
              • Richland Center WI, USA.
              Welcome to the cult, Kelly!
              • gad5264
                • 1407
                • Columbus, Ohio, USA
                • BT3000/BT3100NIB
                quote:Originally posted by jxyoung
                Craftsman micro torque wrench $26 off. Now $48. 9/16 to 9/18
                I would consider something else.
                These do not have lifetime warranty, Husky@HD,and HF ones do. I have both and the Husky is better in 1/2" drive size due to 250
                Grant
                "GO Buckeyes"
