Greetings from a newbie
  • evgenyb
    • 21
    • Folsom, CA, USA.
    Hello Everyone!
    After months of reading I finally register just to say BIG thanks to everybody at this great forum!
    BT3100 new owner,
    I Look forward to get all the info you post here!
    My best,
    EugeneB
    WELCOME Eugene! Congratulations! And Enjoy the fun here!
      Welcome to the Asylum, Eugene!
      • gmack5
        • 1972
        • Quapaw, Oklahoma, USA.
        • Ryobi BT3000SX & BT3100
        Welcome Eugene,
        Congratulations on the acquisition of your BT3100 and welcome to the "family".
        One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the preceeding one, so you MUST keep them in sequence.
        Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes. The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
        entire saw.
        Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
        You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/ The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site). One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
        This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea. One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
        A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
        Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
        You might also want to check out the "FAQ" shown in the link below.
        http://www.bt3central.com/forum/topi...TOPIC_ID=12490
        It'll answer a lot of your questions.
        George
        • Wood_workur
          • 1914
          • Ohio
          • Ryobi bt3100-1
          have fun, and be safe.
          Alex
          • bigstick509
            • 1227
            • Macomb, MI, USA.
            To the best forums on the Net.
            • Ken Weaver
              • 2417
              • Clemson, SC, USA
              • Rigid TS3650
              Welcome aboard Eugene!
              Ken Weaver
              Clemson, SC
              • monte
                ***** Windbag
                • 5242
                • Paw Paw, MI, USA.
                • GI 50-185M
                Welcome to the group Eugene! Be safe and enjoy your new saw.
                Monte (another darksider)
                • gad5264
                  • 1407
                  • Columbus, Ohio, USA
                  • BT3000/BT3100NIB
                  Welcome and be sure to post project pics for all to see.
                  Grant
                  "GO Buckeyes"
                    Greetings to you and welcome to the forum. Enjoy it.
                    • silverfox
                      • 2863
                      • Richland Center WI, USA.
                      Welcome to the cult, Eugene.
                      • Tom Hintz
                        • 549
                        • Concord, NC, USA.
                        Welcome!
                        One note: You are not allowed to blame the need for tools on us for at least a year. After that, we made you want stuff!
                        Tom Hintz
                        NewWoodworker.com LLC
                        • WEG
                          • 298
                          • Nahant, MA.
                          Hi Eugene;
                          Boy, you have self control. Lasting months before getting the BT3100 I think I was able to hold off about three days...these guys are brutal to my checkbook! But I love it What a great way to spend your time. Noise, sawdust, glue, more noise, some smoke, woo hoo !!
                          You probably already found out this is the best bunch of woodworkers you will ever run into. Welcome aboard and as Monte said, Be Safe.
                          WEG
                          • lcm1947
                            • 1490
                            • Austin, Texas
                            • BT 3100-1
                            Yes, welcome Eugene. Hope to be seeing you around. Great fun isn't it? Enjoy and watch those fingers and hands.
