Who knew that planing was harder for the beginner than using any of the power tools ?? haha There must be an art to this but I think some of it is the adjustment side as well.
I bought a jack plane to get me started. I framed out two windows in the house over the weekend with pretty good results. Just had to plane down the back edge of some 1x6's for the side pieces because the windows were just under 6" deep. Just went between planing and fitting back and forth until I got what I wanted and it worked out fine.
But my first big project I want to be a workbench. I am mostly settled on the plans for one in the Dec/Jan issue of Family Handyman. Anyone seen that ? I was a little worried about the bench top which is glued up from 2x4's on edge. I didn't know if I could plane and sand that smooth so I wanted a little test piece. I glued and screwed and clamped five pieces of scrap 2x4 material that were each about 18 inches long.
I tried to use the plane to smooth that and I really felt like I made things worse more than better. The manual for the plane really told me nothing about what the adjustments are for the blade depth and angle. I feel like the plane is digging in way too much and it simply gets caught in the forward stroke and leaves a gouge in the wood. Any suggestions in the form of a tutorial ?
I fought through it and sanded it with a 3x21 belt sander at the end and was actually fairly pleased with the end result. But I know there's a right way to use the plane and I'm clearly not doing it.
Thanks in advance !
Steve
