dado blade or router for dados?
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    dittos on the dados, dudes.
    • vaking
      • 1428
      • Montclair, NJ, USA.
      • Ryobi BT3100-1
      Mstol,
      I don't see the point of mounting dado head onto sliding SMC. Even the biggest sliding SMC can only slide about a foot, so you can make with it a foot or less long dado. That size dado you will be better off with router anyway. If you want to pursue the idea of sliding dado head - go for RAS (Radial Arm Saw). RAS is similar to sliding SMC but the moving range is bigger and they definitely take dado heads. I believe cutting dados is the main reason people still use RAS.
      Alex V
