Just bought my BT3100
  • jangus
    • 5
    Well, after lurking here for close to a year now, I make the plunge and bought one. I missed out on the before Christmas sale, but oh well.
    Any advice for a newbie BT3100 owner will be appreciated.
    Already made a little sawdust with it.
  • JonBoy
    • Sep 2005
    • 129
    • Hampstead, NC, USA.
    Im fairly new to the saw myself but sugest building outfeed table ASAP. Its super nice to have and for me it makes the saw safer to use.
    • gmack5
      • 1972
      • Quapaw, Oklahoma, USA.
      • Ryobi BT3000SX & BT3100
      Welcome Jangus,
      Congratulations on the acquisition of your BT3100 and welcome to the "family".
      One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the one before it, so you MUST keep them in sequence.
      Regardless of what you've read or others have told you, NEVER NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes. The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
      entire saw.
      Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
      You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/ The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site). One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
      This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea. One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
      A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
      Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 9" side of the 30-60, if possible.
      One of the other "tricks" that I've discovered is to take a piece of "Wax" paper, fold it several times and rub it in the grooves that the "T" nuts that lock your Rails in place ride in.
      Makes the Rails move smooth as Butter.
      George
        Welcome to the Asylum, Jangus.
        • Wood_workur
          • 1914
          • Ohio
          • Ryobi bt3100-1
          as for the out feed table, some 2x4's with a lap joint in the middle to form a x frame screwed to a 4x4' piece of ply with levelers on the bottom works great. If you need more support for some cuts, then just drag it back a little.
          And also, welcome.
          Alex
          • monte
            ***** Windbag
            • 5242
            • Paw Paw, MI, USA.
            • GI 50-185M
            Welcome to the group Jangus. Enjoy your new saw.
            Monte (another darksider)
            • silverfox
              • 2863
              • Richland Center WI, USA.
              Welcome to the cult, jangus....(first name?). You will enjoy that saw.
              • Napoleon
                • 249
                • Milwaukee, wi, USA.
                Welcome to the group! Any questions, just ask, and you'll get a lot of answers from some very knowledgeable people.
                Be safe, and of course post your completed projects for all to admire!
                Happy Holidays
                Mark
