Muddler,
I've managed to squeeze in floor tools for the most part. In your situation, it just doesn't look like you've got the room.
So where does that leave you? Benchtop tools can still be fine quality, so it's not like your projects would end up crooked or something. You're just likely to be limited to somewhat smaller projects.
For example, et's take a jointer. I don't know the reasonable lenght limit for using a bench-top jointer, let's say it's four feet. Well four feet is a pretty long stick on most furniture projects.
So I'd go ahead a spec in bench top tools as much as you need to. Nobody, except other woodworkers, will have a clue there is even a difference. And even we will still appreciate the results in Fishished Projects.
Good luck,
anti-communist block warden
Good luck,
