T-Track question
  • waterpro
    • 60
    • Grover Beach, CA, USA.
    T-Track question
    I just ordered the Rockler T-Track system and 4 peice router accessory kit. I am curious how to install the T-Track system. After I cut the groove for the track do you guys glue the track into place or are there screw holes in it so it can be fastened to the table? I've never actually seen one of these in person so I am not sure what I should expect in terms of installation. I would think it would screw into the table so that it can be removed in the future and put into a different table if need be. Just curious though.
    Thanks!
  • os1kne
    • 901
    • Atlanta, GA
    I believe that the Rockler t-track does have screw holes, however I have had great success with just sticking it down with Liquid Nail (construction adhesive available at any Home Depot, Lowes, etc. - usually near the caulk).
    Granted the Liquid Nail solution is not as temporary as screws, however if I recall correctly, the Rockler t-track holes are spaced a bit far apart - I tend to use t-track pieces that are fairly short (DP table and jigs), so I would find myself in a position of having a t-track with only 1 screw hole - so I needed to either use an adhesive or drill more holes. If I were installing a long section of t-track in workbench or something with a thick surface I would probably use screws.
    Good luck.
    • Tom Miller
      • 2507
      • Twin Cities, MN
      As was mentioned, there are screw holes provided. Depending on how you use the track, you may or may not need more holding power.
      There are some jigs/fixtures (stop blocks, etc.) that, when fastened to the t-track, come in contact with the top surface of the t-track. Tightening will only tend to compress that item and the t-track -- no real need for extra holding power.
      Other jigs/fixtures (hold-downs, etc.) apply leveraging pressure, and will pull your t-track out of its slot if not held down well. In this case, drilling and countersinking more screw holes, or using some adhesive would be a good idea. Take into account the material you're screwing into or adhering to.
      Regards,
        IIRC the Rockler track comes with holes at 12" centers. If your jigs or fixtures apply any lifting force, you may want to drill some more if you'd rather not glue the track down. Ditto if you cut the track and don't end up with a hole conveniently located near each end.
        • autiger1
          • 549
          • Tampa, Florida, USA.
          I recommend epoxy.
          • monte
            ***** Windbag
            • 5242
            • Paw Paw, MI, USA.
            • GI 50-185M
            I've used screws to hold it in place but I've also used polyurethane glue with good results.
            Monte (another darksider)
            • Tom Hintz
              • 549
              • Concord, NC, USA.
              I also use the Rockler track, often in pieces. I just drill a hole near the end if I need it and c ountersink it with a 1/2"-diameter drill. That gets the screw head down where it doesn't bother things sliding in the track.
              Tom Hintz
              NewWoodworker.com LLC
