I've watched David Marks use a glue roller many times. I have a small one (part of a kit) I just used for the first time. Lousy. Do y'all use one? Good source for a GOOD one? Rockler doesn't list any.
Glue roller?
I used to use one when applying glue to the edges of boards I was going to edge join. It was a pain to clean and I quit using it. I keep acid brushes around for spreading glue. They work fine and are simple to clean.Monte (another darksider)
http://community.webshots.com/user/monte49002 -
I use the roller in this set:
http://www.woodcraft.com/family.aspx?familyid=4374
Like Monte I usually use acid brushes, but for larger areas I do use the roller.
After I finish with it I wash it with warm soapy water. I find it cleans fairly easily IF I remember to wash it while the glue is still wet.
kenComment
Like Ken and Monte, I keep acid brushes in my glue caddy. I also save the plastic 'credit cards' that come in the mail 30-40 times a week. Great for spreaders on large surfaces.
I do have a bottle with a roller and a biscuit slot head. It works ok, but don't use it much.Don, aka Pappy,
PlatoComment
Adding to what Gary said, big stationary stores and repro/drafting supply houses will sometimes have them, too. "Speedball" is probably the biggest brand name (and is also often used as a generic name for these rollers, in the same way that any tissue is a "Kleenex" to some people).LarryComment
I tried a roller-on-glue bottle, and wasn't impressed with the combination. I tried the roller by itself, but I think it was too slippery to roll well. I'm guessing not all glue rollers are created equal.
I've been using the "credit card" system on larger area glue-ups for a while now, and really like it. I cut tiny notches on the edges spaced out about 1/4"-1/2" (kind of like a tile mastik trowel) to leave behind just the right amount of glue.
For edges, I use a brush.
Regards,
Use "pinking shears" (ask your wife, if she sews, if you can borrow hers) on the edge of a credit card. You get nice little saw-like teeth, great for spreading glue.- David
“Be yourself; everyone else is already taken.” -- Oscar WildeComment
You're better off getting your own pair. If LOML found me cutting plastic with her good scissors she'd screech loud enough to call every bat in the seven-county area.quote:Originally posted by dlminehart
Kinda' like if you found her using your best chisel as a screwdriver, dontchaknow [:0][:0]
Bob
Bad decisions make good stories.Comment
ugh! using a chisel for a screwdriver - you're givin' me shivers just thinking about it, Bob!!!! That's why I gave my wife a nice set of butter knives for all her screwdriving needs...[^]Comment
I'm going to get the woodcraft kit, I think. I like the biscuit applicator, though I think I did see this kit at Rockler at some point in the past.
Go Steelers!Comment
GaryComment
Keith, I have what I think is the same biscuit applicator, although mine came alone and not in a kit. It really doesn't work very well ... I tried it a couple-few times, and went back to just shooting a little glue into the slot and then hitting it with an acid brush. YMMV.LarryComment
I agree with Larry. I tried the biscuit applicator and ended up pitching it. I use an acid brush.Monte (another darksider)
http://community.webshots.com/user/monte49002Comment
