quote:Originally posted by Tom Miller
One good reason to use the miter slots is that with a single runner on the sled, you could have a "two kerf" sled. Use the right slot for 90 degree cuts, and the left slot for bevels.
The accuracy should be OK with one runner if it is long enough, and if you remember to keep pressure against one side of the slot as you do the cut to reduce any "play". I've had good results with this sled so far.
