Got the HF DC and accessory kit but...
  • lago
    • 473
    • Lago Vista, TX.
    has anyone found a use for the 6" dust hood or 12" table saw dust hood? IIRC, my tablesaw has a 2 1/2" dust port at the rear. Just wondering how these two items would be used.
    Ken
  • final_t
    • 1626
    Nope. And not the Y or the blast gates, among other bits. One of the reasons why I'm not fond of the kit.
    • dkhoward
      • 873
      • Lubbock, Texas, USA.
      • bt3000
      I adpated the 12" dust hood to my jointer and the 5" dust hood to my band saw. I really haven't used the y but the blast gates are hand if you have permanent piping for your system installed.
      Dennis K Howard
      • jbalders
        • Oct 2003
        • 298
        • Vienna, VA, USA.
        • BT3100 + Shopsmith
        I made a down-draft sanding box and attached the 6" dust hood in the middle of the side. The sanding box is a 2'x4'x6" pine box, with two supports across the top, 1/4" perfboard on top and 1/4" hardboard on the bottom. Supposedly the hood works on the HF jointer, but I don't have one, so I can't say for sure.
        I still haven't found a good use for the table saw hood though except for collecting dust.
        For attaching a DC to your saw, if it's a BT3K, you'll need either one of these, found here or here (part #144534).
        I'm not sure who makes the woodcraft one, but they both should be the same thing. Keep in mind that the 2-1/4" end is off-center, don't get the one where the smaller hole is centered in the adapter. The 2-1/4" fits inside the hose connector on your BT3K.
        Jeff
        Jeff
        • monte
          ***** Windbag
          • 5242
          • Paw Paw, MI, USA.
          • GI 50-185M
          Instead of buying the HF kit I bought just the things I needed. No left over parts that way. My local Menards carries a good selection of dust collection fittings.
          Monte (another darksider)
          • Popeye
            • 1848
            • Woodbine, Ga
            • Grizzly 1023SL
            Well I must be an odd ball. I've used about all of it. I bought two kits because the hose is cheaper that way than anywhere else. I hard piped most of the system and used all 4 blast gates. Used one 6" hood for my jointer. One 6" for my RAS hood. Cut down a 12" hood for my BS this week. Probably will find a use for the other one before it's over. Pat
            • ironhat
              • 2553
              Give yourself some time. You will find uses for most if not all of it.
              Blessings,
              Chiz
                I'm with Pappy. I bought TWO accessory kits, and have used almost everything from both of them.
                For one of the table saw hoods, I built what amounts to a floor sweep for the top of my router table ... a square frame that holds the hood at about a 5 degree angle, with the frame member on the "high" edge cut away so dust can enter (hard to describe in words: as I said, envision a floor sweep). I clamp this contraption to the top of my router table when I'm doing freehand or template work that does not require a fence, and it does a remarkable job of collecting almost all the dirt.
                I made a similar, smaller dust collection fixture using one of the jointer hoods. Another use for these, especially if you cut them down a little, is as the dust pickup on a router table fence. Of course this means using a 4" hose connected to your DC, rather than the more common 2-1/2" hose of a shop vac.
                • stewchi
                  • Apr 2003
                  • 339
                  • Chattanooga, TN.
                  I used all of the items from mine as well, I used one of the hoods making a belly pan for under the BT to collect the dust that falls below, I used the other on the back of my router table to collect dust from the router, I also used one of those in contraption I rigged together to collect dust when routing dovetail with the HF dovetail jig.
                  I put all the pieces with various fitting etc that I collected when piping my system and put them in a 5g bucket. The bucket empties over time as you find new and interesting ways of putting large amounts of dust in the air.
                    Here's how I used the small hood on my jointer.
                    I'll admit that I had a pile of parts for a while, but over the last couple of weeks I seem to have whittled it down quite a bit. It's a nice "starter" kit, providing some useful parts, as can be seen by the creative ideas already presented.
                    • paulstenlund
                      • 230
                      • Puget Island, Wa.
                      Does anyone have the SKU for the accessory kit, I can't find it on the web site
                      Thanks
                      Paul
                      • ironhat
                        • 2553
                        http://www.harborfreight.com/cpi/cta...emnumber=47911
                        Blessings,
                        Chiz
