three questions:
1. I'm working on my first project. Shelves out of 1x6 red oak. I am staining a test piece with an oil based ebony stain. I followed the directions on the can. It's been two days since the second coat and it is still tacky and leaves stain on my fingers when I touch it. Is this normal. I have the piece in my garage. It's been ~50d in the day and mid 30's at night. If temperature is the issue, I'm not sure what to do as the garage is the only work area that I have. Any ideas?
2. Do you use throw away brushes for painting glue on biscuits? I see Norm brushing the glue on his biscuits with a small brush. Can you clean wood glue off of a brush or do you do you buy a bunch of throw aways?
3. I read that you shouldn't use tack cloths after sanding before staining because it contains linseed oil? Can anyone confirm this?
Thanks in advance
Jason
Thanks in advance
Jason
