Wow! Enjoying this new hobby...
  • mcdowch
    Handtools only
    • Sep 2005
    • 3
    • Marietta, GA, USA.
    Folks,
    I have to say, after lurking around this forum for several months, I finally bought a BT3100 and started down what I think will be a great hobby.
    My wife gave me a couple of projects to start with. Interestingly enough, the the span of 4 hours, I learned that table saws produce a LOT of dust (next time move the SUV), the blade IS sharp (move the hands) and kickback is dangerous (again - move the SUV).
    In all seriousness, I want to express my appreciation to all who contribute to this forum.
    Regards,
    Chuck
    \"You don\'t drown by falling in the water - you drown by staying there\"
  • Jim Boyd
    • 1766
    • Montgomery, Texas, USA.
    • Delta Unisaw
    quote:Originally posted by mcdowch
    Folks,
    Regards,
    Chuck
    Welcome! Remember to move the SUV and hands! Never, ever, EVER look at a lathe or hand planes[]
    • monte
      ***** Windbag
      • 5242
      • Paw Paw, MI, USA.
      • GI 50-185M
      Welcome to the group Chuck! Be safe and enjoy your new saw!
      Monte (another darksider)
      • Popeye
        • 1848
        • Woodbine, Ga
        • Grizzly 1023SL
        Welcome aboard, Be safe, Have fun. Pat
        • Tom Hintz
          • 549
          • Concord, NC, USA.
          Chuck,
          It sounds like you have learned a few of the more important facts of the woodworking life all in the first day! Of course, now that you have admitted to knowing about the hands/blade problem, if you ever do that again, we all get to slap you on top of the head. Everybody wants you to have fun, not hurt yourself so remember that lesson, pay attention always and keep exploring woodworking!
          PS: Heed the advice about not looking at lathes. I have hand planes also but it is the lathe that causes the major disruptions (and dissappearing trees in my yard) in my life.
          Tom Hintz
          NewWoodworker.com LLC
            Welcome to the forum Chuck. Glad you decided to join us.
              Welcome to the Asylum, Chuck!
              Ignore the Chicken Little-ish warnings above about hand planes. They are not addictive! All you need is a good #3 or #4 for smoothing, a #7 or #8 for jointing, and a couple of decent block planes for touch up and shaping. Maybe an 80 or 81 scraper...a 12 and a 12 1/2 scraper....at least one 112 scraper...But they are not addictive!!!!
              • Rounder
                • 1287
                • Sanford, FL, USA.
                Welcome to the group. I am sure someone has told you, or you have already read, about the redline. As far as the lathe and planes, it is like watching a horrible accident, you can't help yourself. Then comes the great bandsaw debate. Followed by a discussion on what chisels you should own.
                I would tell you to run away, but alas it is too late. Your stuck here with the rest of us addicts.
                George AKA Rounder
                "Amarillo Slim, the greatist proposition gambler of all time held to his father's maxim; You can shear a sheep many times, but you can skin him only once."
                • jhart
                  • 1715
                  Welcome Chuck. Actually the addiction starts with this forum. I need to get my daily dose.
                    Welcome aboard Chuck.
                    • gmack5
                      • 1972
                      • Quapaw, Oklahoma, USA.
                      • Ryobi BT3000SX & BT3100
                      Welcome Chuck,
                      Congratulations on the acquisition of your BT3100 and welcome to the "family".
                      One of the first things you need to do, after you get your BT3100 Saw assembled is, following your Owner's Manual, go thru the entire set-up proceedure, step by step, in the sequence laid out in the Manual. Each set up proceedure builds on the preceeding proceedure, so you MUST keep them in sequence.
                      Regardless of what you've read or others have told you, NEVER use any wax or lubricant on your saw that contains Silicone, this includes all automobile waxes and polishes and most spray-on furniture polishes. The reason is simple, most of them contain Silicones and they will make your projects difficult to finish.
                      entire saw.
                      Your best bet is to use a "dry" lubricant, such as Teflon (PTFE), Powdered Graphite, or Candle Wax for the Raising/Lowering and Tilt mechanisms below the table top.
                      You might also want to check out the "Articles" section on the www.BT3central.com site. Lots of good maintenance information on your saw and some of the Jigs and Fixtures that BT3Central members and others have designed for it. Located here: http://www.bt3central.com/articles/ The only thing you'll need to access the information is a recent copy of the Adobe Reader (It can be downloaded from the BTcentral site). One of the Articles mentioned is a "Check List", written by Jim Frye. You can find it here: https://www.sawdustzone.org/articles...nce-check-list
                      This list contains all the different areas on your saw that need to be periodically inspected or given some sort of special attention. In other words, a "Preventative Maintanence Check List" or PM. Performing this PM on a monthly basis would be a good idea. One of the other things you'll find there is an on-line copy of the User's Manual in downloadable pdf format (a handy thing to have).
                      A good one will cost you quite a bit of money, $40 - $75, or more. I would recommend that you consider using a pair of Draftsman's 30 -60 and 45 degree triangles instead. You'll find they're not near as expensive and are far more accurate than a run-of-the-mill Carpenter's Square. The 30 -60 triangle should have one 12" leg and the other leg would be 9" long. The 45 degree triangle should have at least 8" legs on either side of the 90 degree corner. That way either one can be put up against the side of the Saw Blade without touching the saw teeth.
                      Just remember, regardless of which measuring instrument you choose to use, check it(them) to be sure they're accurate. When checking the Miter Fence for Square to the Blade with a triangle, use the 12" 30-60, if possible.
                      George
