After finally getting all my small jobs out of the way i am ready to start on my patio cover project.Here's my question * Do i need to cut out the stucco to hang the ledger to the house or can i just hang the ledger on top of the stucco and bolt it to the house.
patio cover part 2
I'll put it this way ... it would be better if the stucco were removed, but you don't absolutely have to remove it (assuming it's sound, not cracked or crumbly). If I was detailing a new building I would always show direct wood-to-wood connections; but of course you're not dealing with a new building. Just make sure you use adequately long lag bolts (or whatever) to compensate for the thickness of the stucco, and you should be fine.Larry -
I checked out the ledger on my patio cover last night. It's mounted outside of the stucco.
This thing is actually a second-floor deck, so it gets some weight on it. I've had to rebuild the deck in the past, but never touched the ledger. It seems to be hanging in there just fine.
JRJRComment
Like Larry said, make sure you use long enough anchors, and make sure you use enough of them. We looked at house last weekend that had a ledger bolted on at each end and nowhere else.David
I just had an important thought (film at eleven!). Are you certain the finish of your house is truly stucco, or is it EIFS (Exterior Insulation/Finish System, often called "Dryvit" which is one of the various brand names)? EIFS consists of rigid foam insulation that is covered by a woven reinforcing fabric and then a stucco-like finish coat ... stucco-like being the operative word.
If your house is very new, there's a good chance it's EIFS, because the builders have gone nuts with this stuff in recent years. And if it is, you'll have to remove it before attaching the ledger since the rigid foam that's underneath what you can see has no structural strength to speak of.LarryComment
thanks for all the info guys . And yes Larry it is real stucco,our house is 4 years old and pretty much thats all they are using out here to finish the new house .It seems i will have to cut the stucco out for one simple reason (MONSOONS) they can get some really heavy rains and strong winds here in east valley of AZ .I really miss Ventura's Ca, weather.Comment
