Newbie safety q's
  • ewl
    • Jul 2005
    • 9
    • Lake Ridge, VA, USA.
    Newbie safety q's
    Hi all,
    Thanks for all the great advice on my last post, when I was trying to decide whether to get a BT3100 to use for my laminate flooring project. I did buy one, and got it set up this past weekend. I'm a little in awe of this very impressive machine-- my prior power tool experience being limited mostly to a drill-- particularly since this one could easily lop off a few digits, or more. (And I'm kind of attached to my digits.) So, I would like to be particularly alert to safety issues as I start exploring this new hobby.
    I've read a bunch of posts and the FAQ (which is awesome), and am wondering what accessories or modifications you'd recommend as "best practices" for the safety conscious newbie. So far, I've got: ear/eye/breathing protection, the Shark Guard (is this a MUST that I should get right NOW?), painting the red line (gonna do it), a knee operated off switch gizmo (?), reading the manual, feather boards and push sticks (any good commercial ones?). Anything else you wish you'd used from day one? Or any that are more essential than others?
    Thanks a lot. This is a great forum!
    ewl
  • rbfunk
    • 400
    • Garfield, NJ, USA.
    The number one safety tool is the good old Mk.1 brain assembly. Second is eye protection. (sorry Norm)
    If it looks or feels unsafe, it is. Plan exactly what you want to so before powering on. It looks like you've read everything you should so no problems there.
    FWIW,I am running a non-modified saw. Well, I do have the red line which has saved the tip of the miter fench once.
    Regarding the push stick, I'd say make one. You can make it to fit your hand and those digits you are attached to.
    Welcome to the group! Don't be afraid to ask questions.
    Bob (who is a bit of a safety freak)
    Oh what a tangled web we weave, when we are all hopped up on caffine.
    • Derrick
      • Jul 2005
      • 206
      • Kansas City
      Welcome Ewl: I am also a newbie. I have only had my BT3100 since Fathers day but I think I can tell you from experience to make absolutely certain that yout rip fence is parallel to the blade and perhaps a little wide at the rear of the blade.
      I would not say the Shark Gaurd is a must have but it is extremely comforting to know it's there. It is a well built gaurd and the clamp acts as hold down giving you a better contol over the stock.IMHO...
      And listen to the experts on this forum. These guys are good.
      • scmhogg
        • 1839
        • Simi Valley, CA, USA.
        EWL,
        Bob is right about brain freeze. My only nick, a tapered left pinkie tip, was caused by inattention while making repetitive cuts.
        You probably don't need the Shark Guard immediately. [Sorry Lee.] However, since your going to want it soon why not do it now and reduce your frustration and risk. Before I got my SG I rarely had any blade cover at all. I would remove everything when I dadoed and when I used a sled. It was such a hassle and sharp that I would leave it off. The SG solves all that. So, you are more likely to use it.
        Rockler has a set that includes push sticks and feather boards.
        Steve
        • Handy Al
          • 416
          • Worthington, OH, USA.
          Check out Rockler. Sometimes they have ther 4-Piece Safety Kit on sale.
          I comes with a magnetic push stick that keeps it handy on the BT3, 2 angled push blocks, and a featherboard that fits in the miter slot.
          "I'm growing older but not up." Jimmy Buffett
            Not much in your profile, but I'll go on the assumption that you are married. One of the biggest causes of accidents is lack of attention to what is happening in front of you.
            Set a firm rule that anytime you have the saw, or any other tool, powered up your wife, kids, or visitors to the work area do not approach until you have signaled them that it is ok. A split second of distraction is all it takes to cause a major accident.
            I extend this rule to ALL tools, power or hand. A chisel or hand saw can do a lot of damage.
            • Ken Weaver
              • 2417
              • Clemson, SC, USA
              • Rigid TS3650
              Welcome aboard EWL - glad to have you and glad you are safety conscious. I suggest you spring for the Shark Guard very soon. After your first encounter with the pawls you'll be glad you spent the money on it. The stock pawls are the most frustrating thing about the saw and they will stab you, and the piece of beautiful oak you were cutting. Its just the smartest thing you could spend money on after the saw itself IMO.
              Ken Weaver
              Clemson, SC
              • JohnnyTest
                • 172
                • Joppa, Maryland.
                I find the most important thing my pushstick. I got a nice rockler pushstick that has a magnet. If your hands aren't ever near the blade by using the pushstick, you should be safe in that regard.
                I would also do something like you said with the oversized off switch. I haven't done that yet, but everytime I am trying to find the switch I say to myself that I need to make it bigger.
                Be safe !
                • WEG
                  • 298
                  • Nahant, MA.
                  Hi ewl;
                  Welcome to the forum. This is a great place and the folks are really helpful. You got a lot of great advice. I would recommend you get a "Grripper". It will keep your digits away from the blade when ripping and gives good control of the wood you are sending through the saw blade. Eye protection is a must and "think" before you cut is always required. When making a cut, if it doesn't feel right, it probably isn't... hold fast and shut down. Also I think it helps to keep your eyes on the blade and fingers away until all stops! A spinning down blade can do a lot of damage. Just take your time, don't rush and be safe.
                  WEG
                  • Mainemarc
                    • 673
                    • Portland, ME, USA.
                    Hi Ewl:
                    Good advice all around, but I'll add my recommendation that you pay particular attention to Bob and Derrick's posts. Bob is right on that so long as you use your brain, you'll develop a very reliable sense of judgment of what is safe and what isn't. Pay attention to any nagging, half-heard voice in the back of your head that causes you to hesitate before attempting something.
                    And Derrick is right about aligning that rip fence. Kickback caused by wood stock getting wedged between the moving blade and the rip fence - even for an instant - can have lightning fast consequences.
                    Marc
                      This is true. Remember to stay alert.
                        The only thing I can add is that you may want to make some feather boards and push sticks yourself. Besides it is good practice in learning to use the saw.
                        Here are some links for making your own:
                        http://www.blackanddecker.com/Projec...941_13985.html
                        http://www.wood-worker.com/tips/featherboard.htm
                        http://www.wood-worker.com/tips/push-stick.htm
                        http://www.blackanddecker.com/Projec...941_13986.html
                        • sscherin
                          • 772
                          • Kennewick, WA, USA.
                          Wear shoes in the shop!!!!
                          I got a 1" staple burried in my foot last weekend because I was lazy..
                          this brings me to point #2.. keep the shop clean.
                          William's Law--
                          • ewl
                            • Jul 2005
                            • 9
                            Hi all,
                            Thanks a lot for all the great tips and advice. Having access to this group is very reassuring and is a big part of why I went with the BT3100. I'll keep you posted on my progress! (Haven't sprung for the Shark Guard yet, but tempted....)
                            • BobSch
                              • 4385
                              quote:Originally posted by ewl
                              Hi all,
                              Don't be tempted, just do it. The Shark is arguably the best addition you can make for the BT3. At least if you like to be able to count to ten without taking your shoes off.
                              Bob
