DP Table (ShopNotes)
  • vinht
    • 391
    • North Andover, MA, USA.
    I built this table primarily to start cutting mortises on the drill press. The last pic shows me testing that out. This is so much better than cutting blind on a router table!
    I know other members have made this table but I haven't seen it on the forum so I thought I share. I did not deviate from the plans other than adding a t-track to the face of the fence for stop blocks. The second pic shows the table with arms partially extended.
    Enjoy,
    Vinh
    <center></center>
    <center></center>
    <center></center>
    A Woodworker\'s Journey
    http://vinht.home.comcast.net
    Very good job. Looks professional.
    • tropicaffair
      • 85
      • Gloucester, MA, USA.
      Vinht,
      Nice job - been thinking about which table design to use on my DP350, been leaning towards this one. Let me know how it grows on you.
      Russell
      • Tundra_Man
        • 1589
        • Sioux Falls, SD, USA.
        Nice job. You'll get some good use out of that.
        Terry
        • vinht
          • 391
          quote:Originally posted by tropicaffair
          Vinht,
          Thanks. This worked out well because of how the table was attached to the drill press. Since the table has a "hollow" core to allow for the sliding rails, it worked out nicely for attaching to the slots on the original table prior to screwing on the shop-built top. If you decide to go this route I could unsrew the top and show you what I did.
          Vinh
          • tropicaffair
            • 85
            Thanks for the additional info. I'll take you up on your offer but there's no real rush until after ski season - shop time is at the typical seasonal low right now. The DP table is in the top three "projects to do next" list.
            Russell
            • monte
              ***** Windbag
              • 5242
              • Paw Paw, MI, USA.
              • GI 50-185M
              Nice work Vinh!
              Monte (another darksider)
                I saw that table and wondered how it would work. You did a first rate job.
                • Ken Weaver
                  • 2417
                  • Clemson, SC, USA
                  • Rigid TS3650
                  I made one but used MDF, obivously its very stable. Nice work Vinh!
                  Ken Weaver
                  Clemson, SC
                  • vinht
                    • 391
                    How long ago did you make your table and do you still like the design? Post pics of your version if it's not too much trouble.
                    Vinh
                    • mr.g
                      • 66
                      • Richfield, MN, USA.
                      I'm in the process of building the exact same drill press table. As a matter of fact, I have the issue (#74) of Shop Notes that this in here with me now at work. I was going to read over the article one more time as well as check prices on t-track. So far I've gotten the base, spacers, and guide blocks cut out and the metal rails cut to size.
                      Where did you get your t-track and Star knobs from? I'm still checking on sources/prices for these items.
                      I also like your idea of including t-track on the fence.
                      I hope mine turns out as nice as yours did.
                        Another one of those 'Someday' projects. Nice work, Vinh!
                        • Ken Weaver
                          • 2417
                          • Clemson, SC, USA
                          • Rigid TS3650
                          Vinh
                          Ok - gotta take them first. Made it last fall but I didn't round off the corners like the plan called for, its still on my to do list. Will post tonight.
                          Ken Weaver
                          Clemson, SC
                          • vinht
                            • 391
                            G-
                            I bought my tracks from Rockler during one of their sales. I plan on going back to get smaller knobs for the stop blocks. There are many other tracks to consider depending on your needs. The rockler tracks are nothing special but it serves the needs for this table. One of the woodworking mags did a comparison of the major brands. Unfortunately, I can't remember which magazine. If I find it I'll repost their results.
                            By the way, be sure to leave enough room for the slides to glide easily. Mine takes a bit of force. As you assemble all the pieces together it will get tighter and tighter. I may consider removing the top to loosen it some more.
                            Vinh
                            • GeekMom
                              • 752
                              • Bonney Lake, WA.
                              • Shopsmith Mark V
                              Nice table, Vinh. ShopNotes #74, hmm? Need to check the library!
                              Karen
