Evangeline's Dresser
    I started this more than 1 1/2 years ago and I'm calling it done (except for the back but close enough).
    Overall the design is mine but I took some inspiration from a piece I saw in FWW.
    Made of walnut and poplar with plywood drawer bottoms. The walnut came from my neighbor's tree which fell down in a storm 2 1/2 years ago. I helped the sawyer saw it into lumber. The back will be walnut boards from the same tree.
    Dimensions are 42"H x 48"W x 21"D. The sides, top, and bottom are just 2 boards wide. Nice to have access to such wide boards. The sides are not bookmatched, but if you put the sides side-by-side, they would be.
    Handcut half-blind dovetails. Not my first time doing DTs, but my first time doing half blinds on a real project. The only other time was as a homework assignment when I took WWing classes.
    Thanks for looking,
    Paul
  • BadeMillsap
    • 868
    • Bulverde, Texas, USA.
    • Grizzly G1023SL
    Paul -- OUTSTANDING work!! Will be a family treasure a long LONG time! It's why we do what we do ....
    Bade Millsap
    Bulverde, Texas
    => Bade's Personal Web Log
    => Bade's Lutherie Web Log
      That is fantastic, Paul! I love the grain in the ends.
      • durango dude
        • Mar 2011
        • 937
        Wow - I'm impressed!
        Did you by any chance use an Incra Jig for the drawer joinery?
          No. Some close-up shots in this thread. I like skinny pins.
          The tail boards were entirely cut by hand and cleaned up with chisels. I then laid out the tails on the pin board (drawer fronts).
          I made a jig to hold the board vertical while I wasted away as much of the wood as close to the line as I could with my router and straight carbide bit. I did it freehand. Really nerve racking and really tedious! Then I cleaned up the rest of the pin board with chisels to fine tune the fit.
          The first few drawers were a little "gappy" so I glued/jammed in slivers of walnut veneer into the spaces and then hand planed the drawers to flush up the sides to the fronts and to fine tune the fit in the case.
          Paul
          • ironhat
            • 2553
            Really nice, Paul. Is that design in the Scandinavian family? It's a clean one which hints of that particular design. Pappy is right about the grain pattern and it's a shame that the sides are usually hidden against a wall or other furniture. Anyway, good job!
            Blessings,
            Chiz
              Its awesome Paul, great work!! Did you bead the fronts after assembly? Just curious because it looked like such a small amount of wood left in the drawer front behind the beading, I could imagine assembling and cracking that area. Having your own colossal walnut boards must have been a nice experience
                Yes, I'd say it's a close relative.
                Did you bead the fronts after assembly? Just curious because it looked like such a small amount of wood left in the drawer front....
                Busted. The bead wasn't part of my original "design" but the close to finished product looked boring. Not sure if you remember the Maloof dresser, but the drawers and cabinet had radiused curves which gave nice shadow lines.
                There was just enough meat left on the fronts for me to pass the assembled drawer through a beading bit on my router table without eating into the drawer side. I fubared the top of the top drawer. I had to cut off a 1/8" square strip from the top edge and reglue in a patch. There were one or two other spots where the poplar peaked through, but I patched the area with a little veneer. It's like it never happened.
                Paul
                  I would never have known from the pics, you did a good job at hiding those, but your right, design changes after construction are dicey. It certainly adds to the piece and you did good by making the changes!!
                    Excellent job Paul.
                      Man, that's a beautiful piece. +1 on the grain in the end panels - awesome.
                      Is it finished with Maloof-mix Poly/tung oil?
                        Thank you.
                        The real question is What finish didn't I use? The third post down on this thread goes through the convulated finishing schedule.
                        http://www.bt3central.com/showthread.php?t=57967
                        My next go around, I'm going to explore a light coat of BLO or tung oil or maybe the same varnish blend followed by a spray on WB lacquer.
                        • SHADOWFOX
                          • 1232
                          • IL, USA.
                          • DELTA 36-675
                          Nicely done, Paul! Thanks for sharing!
                          Chris
