cradle for Elizabeth
  • durango dude
    • Mar 2011
    • 937
    A cradle for Elizabeth (my daughter's American Girl)
    Made from pallet wood! Frame is mostly oak, cradle is pine.
    Nice looking...well done. What did you use for the pivot, and do you have a finish in mind?
    • durango dude
      • Mar 2011
      • 937
      cm - I used my lathe to make a tapered dowel. (see 4th photo). The taper holds it into the cradle body like a corkscrew. Then used a forstner's bit to create a 1/2" deep slot on the frame (you can see that in the 4th photo, as well). The tapered dowel fits perfect (router would be better - but I haven't finished my router table)
      I stained the wood with some fruitwood stain. I don't like varnish, much --- have never been good at it --- so it messes up my projects more than it finishes them.
      My daughter is very happy with plain ole stain.
      Feet ---- lap joint
      Cradle assembly -- pocket hole screws
      Frame assembly ---- dowels.
      Kind of fun using such a wide variety of methods---- helps improve my abilities.
        Your daughter would have been happy, and proud, without the stain....
        Nice work!
        • harpinche
          Handtools only
          • Jul 2012
          • 1
          Oh man, this looks really nice! I wish I could get to work of this stature. What was the first thing you made?
          • BadeMillsap
            • 868
            • Bulverde, Texas, USA.
            • Grizzly G1023SL
            Very nice ... heirloom for sure!
            Bade Millsap
            Bulverde, Texas
            => Bade's Personal Web Log
            => Bade's Lutherie Web Log
              That's some mighty fine pallet wood there DD! Good job
                Missed this on the first pass - very nice work with the reclaimed lumber!
                  I can understand your dislike for "varnish", as some woods and finishes look and feel more natural without some topcoating. My suggestion is to consider using a film finish in an almost flat sheen. It will help to keep the wood clean, prevent fraying, and be less subjective to movement issues.
                  • Crockett
                    • 253
                    • Buffalo, NY, USA.
                    Made from pallet wood!! That's amazing DD! Great job on a beautiful piece!
                    Al
