Maloof dresser finished
    The Maloof dresser/changing table is done.
    Solid walnut carcass. Maple drawer runners, maple drawer sides, poplar drawer
    backs, plywood drawer bottoms. Finished with 3 coats Roland Johnson's hot-
    rod varnish, then 2-3 coats shellac to seal in any odor, rubbed out with 600
    grit wet/dry, then wax and steel wool. Drawer insides sprayed with shellac.
    Continuous grain flow on the drawer fronts.
    Details of carcass and drawer construction in Projects section
    I have no idea how Sam Maloof would finish the back of his cabinets but I
    can't imagine he'd slap in a sheet of plywood. I had enough leftover wood to
    make a frame and panel back. I resawed the panels and I'm really happy with
    the way they turned out. Our daughter's name means "angel". I think each
    of the 4 panels kind of look like angel wings.
    This is the first piece I've made for someone else. Kinda' weird. I even signed
    it over to the daughter-to-be on the inside. I promise to look the other way
    if she takes crayons or markers to it. I did tell my wife I'd need it back in
    August so I can submit it to the local fair. I want the big ribbon this year.
    Thanks for looking,
    Paul
  • bigstick509
    • 1227
    • Macomb, MI, USA.
      That is one nice piece.
      I can see your friends daughter giving it to her kids one day.
      They probably didn't think of that one yet.
        Thank you. Actually it's for our daughter. A friend, who is a pro photog, is coming over to take some good pics for me.
        • SHADOWFOX
          • 1232
          • IL, USA.
          • DELTA 36-675
          Nicely done, Paul! Truly an awesome looking heirloom piece.
          Chris
          • lebomike
            • Jan 2008
            • 146
            • Pennsylvania
            GREAT JOB, I love walnut wood projects. You can be very proud of this piece.
            "The power of kindness is immense. It is nothing less, really, than the power to change the world."
              Nice clean lines on a simple and very functional design. Good job on the grain match-up and the choice of walnut was very sound. Actually Maloof would probably use ply (ply comes in about every species if you have access to a good hardwood source) for the back dust shield as the piece will not likely free stand so the back is showing. So.. extra kudo's for going the extra mile to build a solid back panel.
              Question.. are the round dark plugs for screw covers or dowels?
              Very well done Paul...
              • themachine
                • 140
                • Cincinnati, OH
                • BT3100, General Intl. 220
                Great woodworking. Also nice balance with the drawer pulls. Do the drawers slide on the bottom of dividers or are they suspended somehow?
                • Shep
                  • Nov 2008
                  • 710
                  • Columbus, OH
                  • Hitachi C10FL
                  Wow. Now that's inspiring
                  -Justin
                  shepardwoodworking.webs.com
                  ...you can thank me later.
                  • 4estgump
                    • 123
                    • Lawrenceburg, Kentucky
                    atgcpaul,
                    Very beautiful piece. Something to be proud of.
                    4est
                      Beautiful!
                        Thanks to everyone. I give all the credit for design to Sam Maloof. Except
                        for the pulls, I copied one of his pieces as closely as I could from a picture I
                        saw. The only artistic license I took was with the back.
                        Not the most challenging piece I've done but it was fun to "reverse engineer"
                        it from the picture as some of you probably saw in my Projects discussions. I
                        also tried out a lot of new finishing techniques, too. I love that I can't snag
                        any clothes on any corner.
                        Screw covers. I know Sam used screws to reinforce the joints of his chair
                        and then plugged them. I did that, too. I used real wood screws, not drywall.
                        I did not want to risk having them snap. I would have used Miller Dowels for
                        the drawers, but they weren't in stock. I used trim head screws with walnut
                        plugs. In the carcass, it was wood screws with ebony plugs. This thing is a
                        tank.
                        Drawers slide on the internal webframe--not suspended. I put teflon slick
                        tape on the bottom of each drawer side.
                        Genius decision on Sam's part to inset the drawers. If the drawers are just a
                        little cock eyed, you can't tell! The inset is far enough back that the
                        combination of depth and shadows hides all mistakes. I aspire to one day have
                        the design sense he did.
                        Paul
                          Fantastic! A piece that is sure to become an heirloom.
                            Gorgeous. Simply gorgeous. I thought I was doing well for our first when I took a dresser, cut it down and reworked the top to be a changing table.
                              Outstanding work, Paul. I can see your grandkids using that in the future.
