Teak Box
  • shoottx
    • May 2008
    • 1240
    • Plano, Texas
    Very Cool
    Great way to use up scraps and small pieces.
      I am hard pressed to decide what feature I like the best. Is it the legs, the wood combinations, the style?????? They fit together so well. That is a box to be VERY proud of.
        • 10481
        Beuatiful combination of woods, Jon. The inlay really makes the colors stand out and the detail on the legs is fantastic!
          Thanks for all the kind words guys it was a fun little project.
          Given that I just picked up a drum sander this afternoon (see my note under "older performax") i will be able to resaw and thickness some of my stack of exotics without dealing with tearout issues on my planer. This will help with some other ideas I have so more to come.
          • HarmsWay
            • 878
            • Victoria, BC
            Very nice box Jon. Good colour and proportions. Is it your design? The photography is also perfect. I can't imagine what other photography gear you could have needed.
            Bob
              Bob
              Thanks Bob, yes the design was mine, as usual with elements stolen from other things I have seen. The Maple inlay was a spur of the moment addition as I felt it could use a contrast to separate the two darker woods.
              As I do some commerical photography proffesionally I guess I am rather self critical. Normally I would setup my lights so I can be in total control of what is illuminated and how the shadows fall. A good fall back is using the sun which I did in this case but its then tougher to deal with the glare which in this case is rather too intense on the lid. I did use a static diffuser to block some of the harsher glare and give a more even light. As you have illustrated I am probably the only one who can see the problems. If I were to show you two images side by side I am sure you could pick out the "better" one even if you wouldnt know why it was better
                I have a technical question, Jon.
                Did you glue the top all together, or does the center panel float in some way?
                I have been wrestling with that question quite a bit. It is almost always recommended that the panel float, but so many boxes are made with top all glued together.
                  JR,
                  The center panel is glued into the Padauk frame and I then routed a channel for the Maple inlay.
                  One thing you may have missed is that the Teak is actually a veneered bd on a particleboard substrate so its totally stable. I have had these boards for 26 years and they have followed me around the world and are still straight and flat.
                  What really amazes me (now I know much more) is that I was originally able to find such awesome figure with a wood such as Teak on a particleboard veneer, I have never seen anything like it here. They were originaly purhcased in a regular home center in London UK in 1983
                    That is exactly the technique I have been using! Although most of my boxes have been made using the technique in which you make up the whole box, then cut the lid off.
                    I used this technique for a humidor, which is the one case causing some concern. Supposedly the extra humidity of the humidor can cause there to be a problem where otherwise it might not.
                    I have piece of Danish teak veneer that I've been lugging around for a long time, too. It's about 7/8" thick, though, so I don't think I'll be making any small boxes from it.
                      Whats the substrate? Is it substancial enough that you could risk resawing it and applying a cheaper but complementary veneer to the other side?
                        Hmmm, maybe. Have to put some thought into this...
                        • Rand
                          • 492
                          • Vancouver, WA, USA.
                          #27
                          Nice work!
                          Nice photography too.
                          Rand
