Brass Carving Mallet
  • scmhogg
    • 1839
    • Simi Valley, CA, USA.
    I turned the head out of a solid round 2" brass bar. The handle is a Beech ply that is called Compreg. It is soaked in resin and heated under high pressure. Same stuff as WWII propellers.
    I mentioned in an earlier post that I was given 20+ 2"x2"x32" of this wood. It turns and finishes beautifully. Nothing but shellac and wax.
    This one is the first of three that I was able to get out of the bar.
    Steve
  • RodKirby
    • 3136
    • Mao Shan TSC-10RAS
    Beautiful!
    Downunder ... 1" = 25.4mm
      • 5633
      Your work is always nice, Steve, and this is no exception.
      • gerti
        • 2233
        • Minnetonka, MN, USA.
        • BT3100 "Frankensaw"
        Originally posted by RodKirby
        Beautiful!
        I got to agree, that is nice! How did the brass turn?
          That is gorgeous. Do you turn the brass on your standard lathe? Does it take special tools? What are the dimensions of the mallet?
            You did a great job on that.
              A classic piece... Very nice!
              • jking
                • 972
                • Des Moines, IA.
                How does the handle attach to the brass head? Did you turn a round tenon on the brass & drill a hole in the handle? Or the other way around?
                You're not actually planning to use that are you? It looks too nice to use.
                  That sure is pretty. Very nice piece of work.
                    I agree, too darn pretty to use.
                    • scmhogg
                      • 1839
                      Thank you all for your kind comments.
                      I turned the brass and the handle on my Carba-Tec Mini Lathe. I used the duplicator with a carbide cutter to rough out the brass heads.
                      Then I finished them using regular lathe chisels, sandpaper, steel wool and Brasso. I cut them apart and used a forstner to drill round mortises.
                      Then I turned tenons on the handles. I glued them together with epoxy and turned them together to the final shape.
                      I used Gorilla glue to attach a disk of wood to the brass to accommodate the drive spur. I also used the same method to attach to the board for drilling.
                      Vital statistics: Weight 1lb 10oz, Length 8 1/2", Max Diameter 1 3/4", Min Diameter 1 3/8".
                      Steve
                      • jking
                        • 972
                        • Des Moines, IA.
                        Thanks for the step-by-step. Even if I never make something like that, there are several ideas or methods there I may be able to use.
