Fireplace mantle
  • Copper
    • 343
    • Madison, WI.
    Thanks for the feedback everyone!
    Copper, that is an awesome job!!! Tell me more about the cutting and assembly of it! Did you use any jigs or crosscut sleds on the trim pcs?
    Thanks
    The back is 3/4 birch ply. There are actually three pieces (two sides and the upper middle) in irregular shapes. The sides are cut from the upper corners above the fireplace at a 45 deg angle until the cuts are behind the pillars (in order to hide most of the joint). The three pieces were joined using pocket holes. The top is 3/4 birch ply wrapped with pine trim with beads on the top and bottom. The upper pillars are wrapped in 3/4 ply and the bottoms are wrapped in 3/4 pine. All the trim was cut using my compound miter saw. the only jig used was the edge guide for my Bosch router when cutting the flutes. I took a great big sigh of relief after cutting each flute since during several practice runs, the edge guide left the edge of the wood a few times. I imagine it's nearly impossible to repair crooked flutes.
    - Dennis
    "If your mind goes blank, don't forget to turn off the sound." --Red Green
    and yes, it's a potato.
    • GPA61
      • 712
      • Rancho Cucamonga, CA
      • BT 3100 & JET JWTS
      Great looking work!!!
      Claudio
      • ironhat
        • 2553
        Sweeet! Hard to top that one for a while.
        Blessings,
        Chiz
          Wow, again well done!
            Originally posted by scmhogg
            Dennis,
            Your fireplace looks beautiful. A very professional job. Be careful who you show it to.
            Think--Can you build one of those for my house, the wife has been wanting. . . .
            Steve
            ...No problem. First one took 25 hours. Yours should take about 20 since some of the trial and error won't be needed. Let's see, $35 per hour x 20 hours + $185 for materials...Did you just want one????
            Fantastic workmanship!
              Very classic looking. His "Normness" would be proud of you!
