Cherry and Walnut burl wall cabinet
    This is a little cabinet to hang on the wall of my back bathroom. The man-bathroom. I'll eventually need to build a new built-in vanity for that one, so I'll do it to match. I am letting the finish flash some more before I hang this one. I also have yet to pick a hardware scheme for that room, thus no handles.
    It's cherry ply that has been edge banded with 1/8" solid cherry strips. The doors are made of solid cherry, mortised and tenon'd together, with quarter matched walnut burl veneer panels. First time I'd used commercial burl veneer, and it shows. The stuff is a bit of a pain. I don't have a great match on the left door panel, but the right is pretty good. I should have used a filler before finishing this stuff, but I don't really mind it with the variations. No mechanical fasteners but for the hinge screws, all mortise and tenon and glue. It'll hang off of the French cleat in the back.
    One interesting bit is that I made this from scraps from the wine rack project, to be seen here...
    http://www.bt3central.com/showthread.php?t=36591
    The one stile has a big knot that went the whole way through. I was cheap and used the Epoxy that I had on hand to fill it...Bad idea...I should have gone for some 5 minute epoxy. It took 2 weeks to dry enough to work the piece, and it is still a little tacky to the touch.
    The hinges are slow close ones from blum, like those a lot, got em on sale at Rockler a couple of months ago for 11$ a pair. The finish is Seal-a-cell and Arm-r-seal.
    Let me know what you all think. I'll put up more pics as I get it installed and hardware mounted, etc... Also once the vanity is done, but that'll be in a couple of months probably....
    All in all a good learning experience. Whole thing cost me about 30$ as mostly it was scraps, and I got to use my new vac-u-press compact 100, which was really fun.
    Fantastic, Keith! Unless you point it out, no one is going to see the slight mismatch in the door panel.
    • sparkeyjames
      • 1087
      • Redford MI.
      Nicely done. I had to look really hard to see the mismatch. So as pappy said no one will really notice it.
      • footprintsinconc
        • 1759
        • Roseville (Sacramento), CA
        look real cool! i too cant see the mismatch. nice square doors and a great contrast.
        i guess i am going to have to attempt the mortise and tenon jointery one of these days.
        omar
        • Brian in Dawson Creek
          • Jul 2006
          • 128
          • Dawson Creek B.C. Canada
          • Delta Cabinet Saw
          Very nice eye pleasing job, nicely done.
          Brian
          • GPA61
            • 712
            • Rancho Cucamonga, CA
            • BT 3100 & JET JWTS
            Beatiful work.
            Claudio
            • Rand
              • 492
              • Vancouver, WA, USA.
              Very nice!
              Rand
              • rnelson0
                • Feb 2008
                • 424
                • Midlothian, VA (Richmond)
                • Firestorm FS2500TS
                Holy cow, there's a HOLE in it! Seriously, it looks great.
                  Shaweet! The walnut looks really good.
                  Nicely done.
                  • cbrown
                    • 127
                    • Massachusetts
                    Very handsome!
                    It's amazing how much shop stuff you can fit into the upper cabinet... much deeper than it looks from the outside!
                    Chris
                    • Popeye
                      • 1848
                      • Woodbine, Ga
                      • Grizzly 1023SL
                      I must be going through a contrasting wood phase, the more I see of it the better I like it.
                      The cabinet is beautiful. Mismatch??? you told about it and I still can't see it. Fine work. Pat
                      • gerti
                        • 2233
                        • Minnetonka, MN, USA.
                        • BT3100 "Frankensaw"
                        Awesome! I take one...
                        • Two Much
                          • 365
                          • Long Island, NY
                          • (two) Ryobe BT-3's
                          Nicely done, I love the choice of wood.
                          When the bathroom is done and viewed in it's totality, the slight mismatch
                          will never be noticeable. If you didn't point it out, I would have never noticed.
                          Joann
                            Looks great from here Keith! I'd consider that one a keeper. You'll have to remember to post new pictures once the cherry darkens. I think this will get better looking every day.
                              Good job Keith! How did you manage to find time? Did the ankle biter help?
