Help With Red Cedar Chair Finish
  • bigstick509
    • 1227
    • Macomb, MI, USA.
    I built these two chairs 6 years ago and I cleaned and refinished with the original Penofin Ultra two years ago. Well its time to refinish again and I would like some suggestions this time around. I just got done using a cleaner/wood brightener and I'm thinking that knocking done the raised grain with 220+ before using the Penofin should achieve a uniform finish. Two years ago I just washed and refinished and the end result was a bit to dark, the Penofin is a transparent cedar shade so thats what I'm shooting for. The web sites for the wash and the finish are not to DIY friendly. Any suggestions would be greatly appreciated.
    Simple maintenance could be just a clean up with a Scotchbrite pad, and a mild soap solution, and for a finish use 100% pure tung oil. Penofin contains solvents, and is expensive. I would not use steel wool, as particles will rust. If you need a wool, use bronze wool, or a composite non metallic fibered wool.
    • paulstenlund
      • 230
      • Puget Island, Wa.
      I'v been hankering to build a chair, I like the looks of those - Great job BTW - Do you know where you got the plans, or do you still have them
      • bigstick509
        • 1227
        • Macomb, MI, USA.
        This was my first small project when I was just getting into woodworking. At the time all I had was a drill and a router so I choose this source,http://www.woodnewengland.com/Furniturekits.htm
        • paulstenlund
          • 230
          • Puget Island, Wa.
          Thanks Mike, their website seems to be in disrepair at the moment
          Paul
          • BadeMillsap
            • 868
            • Bulverde, Texas, USA.
            • Grizzly G1023SL
            Pointer to "Jake's Chair"
            Hijacking the thread just a bit but for Paulstenlund ... I built this chair a couple of years ago ... a very good chair with very detailed plans at the site linked here ...
            http://www.internetwoodworking.com/w5/chair.html
            If you really want to build from scratch this is a good one!
            Bade
            Bade Millsap
            Bulverde, Texas
            => Bade's Personal Web Log
            => Bade's Lutherie Web Log
            • paulstenlund
              • 230
              • Puget Island, Wa.
              thanks Bade
              I have the info for Jakes chair, I thought I might start with one a bit simpler. Our engineer can enlarge the templates on the plotter that would simplify things a bit. Do you have any hints or tips on construction.
              Thanks again for your help
              Paul
              • BadeMillsap
                • 868
                • Grizzly G1023SL
                I just dove in head first ...
                ... it really wasn't hard to build ... I did find a site on the net that had some pictures of construction ...
                http://www.woodshopdemos.com/adirk-1.htm
                and I did find that helpful ... but basically I just drew up the templates full size and then made fiberboard versions of the templates and went to work ... there are a lot of pieces parts but none of it was over taxing ....
                I used my table saw, my band saw and router all for various phases of the build.
                Good luck!
                btw .. it's a GREAT chair once finished!
                Bade
                Bade Millsap
                Bulverde, Texas
                • paulstenlund
                  • 230
                  • Puget Island, Wa.
                  Thanks again, Bade
                  The woodshopdemos will help a lot - great pictures and personnel, Ilike the scale it down a little idea
                  Thanks again
                  Paul
