Slate Top Maple Tables
  • ejstefl
    • Jul 2006
    • 23
    Here are three tables I made for a Christmas present. The tables are made primarily using maple, with cherry for the feet and splines.
    The construction is mortise and loose tenon. I started off with the plan to make integral tenons, but when I cut the aprons too short, had no choice but to go with loose ones! This was my first time using them, and I really like them.
    The cherry feet are attached to the maple legs with a dowel, off-center to allow the taper of the legs.
    The top frame is 6/4 maple, mitered, and reinfornced with cherry splines. I simply glued it to the apron and leg assembly.
    I used some slate tiles I bought as flooring tiles for the tops. There is a 1/8 piece of hardboard spray painted black screwed into a rabbet in the frame, and the tiles are placed on top of that.
    The finish is three coats of a tung oil finish (I think its an oil and varnish blend) rubbed out with 0000 steel wool between each coat.
    The design is my own, heavily influenced by a hall table David Marks made with a patinaed copper top.
    Thanks for looking!
  • ironhat
    • 2553
    What... you again with beautiful work?! First the cutting boards to whet our appetites and then these tables. Really beautiful in their simplicity and elegance with the contrasting wood in the splined corners. Really nice project.
    Blessings,
    Chiz
      Very nice.
        Those splines are "just right". Nice contrast without overpowering the work.
        Another nice set of pieces, ejstefl!
          Nicely executed. If you use arm-r-seal and seal-a-cell they are oil and urethane blends. I think it looks great.
            Beautiful work.
              Nice looking set of tables.
              • boblon
                • 727
                • Florida, USA.
                Nice work. The simplicity of thier design gives them a classic look I think.
                I've yet graduated to furniture yet. Don't have a lot of room in my shop. At least that's the excuse I'm going with for now.
                Looks great,
                BobL.
                • jhart
                  • 1715
                  Really nice looking tables. I especially like the splines. Nice Job. Someone will be really happy.
                  • footprintsinconc
                    • 1759
                    • Roseville (Sacramento), CA
                    really nice work! i like the cherry feet at the end of the legs. the offset dowel is clever! nicely done!
                    omar
                      Very nice work. I'm a sucker for splines and those do the trick for me!
                      • SwingKing
                        • 131
                        • Fort Worth, TX, USA.
                        Wow! Fantastic set of tables. I've always liked the look of inset slate tables and these look great! May have to borrow your design when I get around to making a set for myself.
                        -- Ken
