I have mentioned these a few times in posts but not posted any pictures. I like others pictures so I decided it was time to post a couple. I have finished 5 windows, two shutters per window. I used the Woodline router bit setup. All except the center louver in each shutter is mdf. The center louver and the frame is poplar. Finish is Kilz Total one primer and then two coats of Resisthane gloss tinted white. I hate the finishing part but the rest is pretty easy. The hardware is from Rocklers - hinges, knobs and catch (the brass knob set comes with a simple catch). Pins came from both Rocklers and Woodline - they are the same. My jigs are some from Norm's plan and some from Woodlines (their plans come with the bit set) and some from me. I put my jig for using my PC 690 plunge router to make the pin holes and also the mortises for loose tenons. I use a woodscrew in the center for tension rather than the special pins that Rockler provides. My shutters are about 5 feet tall with no center rail so the woodscrew in the center helps to keep them straight.
One of my pictures is the setup I use for making the louvers. I messed with this awhile but it works well now. Feather boards are cut up cutting boards which hold the stock down and tight to the fence - in the center where the 3 inch wide louvers are flat. For MDF, I route in two passes removing 1/32 or less on the final pass. For poplar, I do three passes. My router table has a built in homemade lift so it is easy to raise the bit between passes.
