Dropped my miter gage and ended up with this
  • tekton
    • 40
    • Rossville, GA, USA.
    I dropped my miter gage and wanted to check it to make sure it was still square. After I checked it I decided to go ahead and use the pieces of wood I used to check it with to make a small box as I hadn't made one in awhile. With no idea as to what this box was going to look like I re cut the pieces into 4 equal sized mitered sides, then ran a groove in the bottom and a rabbit on top, cut a bottom to fit in the grooves and glued it up. while the glue was drying I cut a square piece for the top ran a rabbit around the bottom and cut a bevel on the sides. So I had my box but thought it was just to plane so I decided to add some splines so after digging through the scrap pile I decided to use some left over purple heart. Grabbed my spline jig and cut for the splines and glued them in. Then I decide it needed a handle on top but I didn't want something big or long, so after some deliberation a decided to cut some bevels on the end of a 3/4" x 3/4" piece of Ph and square cut it at the top of the bevels, I had my handle. I finish sanded every thing and glued the handle on and was going to finish it but decided it was still to plane looking, but didn't really know what else I wanted or could do to it to make it less plane. After some more thought I decide to put legs on the corners but didn't have enough 3/4 Ph to make four legs unless I ripped a strip off a wide piece. Not wanting to rip up one of my wide pieces I decided to go ahead and finish it the way it was. Then it hit me, make legs out of some thin stock I had used to make the splines out of. I made a cardboard template and cut four legs, a little filling and some sanding and I had my four legs. I put the legs on and applied the finish. Anyway sorry about the rambling I dropped my miter gage and ended up with this;
  • footprintsinconc
    • 1759
    • Roseville (Sacramento), CA
    dropping miter or not, man that is beautiful! nicely done.
    omar
    • BigguyZ
      • Jul 2006
      • 1818
      • Minneapolis, MN
      OK, I'm going to run down to my shop and starting dropping all sorts of things. Maybe I'll be able to make something half as nice!
      Seriously though, nice work!
      • bthere
        • 462
        • Alpharetta, GA
        That is very nice. I don't have accidents that work out like that.
        • DonHo
          • 1098
          • Shawnee, OK, USA.
          Very nice. I haven't seen another like it, good design.
          DonHo
          Don
          • Anna
            • 728
            • CA, USA.
            That looks awesome! Do you recommend we all start dropping our miter gauges now?
              Very nice.
              • Knottscott
                • 3815
                • Rochester, NY.
                • 2008 Shop Fox W1677
                Should I drop my Incra, Osborne, or Jet/Woodhaven? ...or maybe that plastic thing that came with my Homier sander!
                ....Beautiful work!
                • sweensdv
                  • 2873
                  • WI
                  • Baileigh TS-1040P-50
                  Just goes to show you that not all accidents have an unhappy ending. Very nice work.
                    • 8801
                    Now if we could just drop some people on their heads and get that kind of results!
                    Great looking design and accent! Sure to be copied!
                    • Hoakie
                      • Feb 2007
                      • 382
                      • Iowa
                      From how high do you need to drop it to get results like that? I have confirmed 36" is not high enough.
                      Great piece, love the handles and accents
                      John
                        Unique, and beautiful.
                        • tekton
                          • 40
                          Thanks all, I don't think I would start dropping things on purpose though The funny thing about it is I came home and noticed the box was missing so I asked my wife where it was and she said she gave it to the neighbor's sister Oh well at least I have pictures.
                            Okay, I tried dropping my miter gage and all I got was a busted miter gage!
                            That is very nice indeed, more a piece of art than a box.
                            • pitbull
                              • 7
                              • sunderland. england
                              Very nice box Now try dropping your wife from a height and maybe she'll stop giving things like that away.
