Turning Ikea Cabinets into a Basement Bar
  • bmuir
    • Jul 2006
    • 63
    • Rochester Hills, MI
    Below are a few photos of a basement bar I just finished for my son. In order to get it down into his basement we needed a modular design. We decided to use Ikea kitchen base cabinets and build up from there. We used two 30-inch and one 24-inch cabinets to build the eight-foot, U-shaped bar.
    Cabinets were locked together and 1x2 screwed to the end to give an extra 3/4-inch for the corner moldings. A 6-inch high stud wall was used on three sides of the lower work surface (covered with black plastic laminate) to support the bar top (also laminated). A 2x6 was screwed to the stud wall and the bar top screwed to the 2x6. The 2x6 support and 3/4-inch, particle board bar top were screwed together using pocket screws. Used Ikea adjustable plastic legs and clips for the toe kicks. Worked great.
    The cabinets were then wrapped with 11/32-inch beadboard plywood.
    Beadboard was stained with General Finishes water-based poly tinted with TransTint dye. Two coats gave the color we wanted and we were done. This saved lots of time. Pine moldings and trim were primed and given two coats of black latex paint.
    Raw wood you see on the bar top is the hand rail at the front and the glass rail at the back. They will be painted black to match the other moldings.
    The whole project took under a month to build in my garage workshop, finish, move and assemble and cost about $425.
    http://i87.photobucket.com/albums/k1...DSCN3391sm.jpg
    http://i87.photobucket.com/albums/k1...DSCN3390sm.jpg
    http://i87.photobucket.com/albums/k1...6/IMG_0463.jpg
    http://i87.photobucket.com/albums/k1...DSCN3395sm.jpg
    So little time, so much wood!
  • TheRic
    • Jun 2004
    • 1912
    • West Central Ohio
    Looks great, when will you be down to do mine?!!!
    Ric
      Looks great and the 'modular' base was a good idea.
        I like it! Great idea to use the modulars and modify to suit. Looking at the front you'd never know it wasn't a custom built unit.
          Nice job. That is very nice.
          • SHADOWFOX
            • 1232
            • IL, USA.
            • DELTA 36-675
            That looks great! Ingenious design as well. Great job and thank you for sharing!
            Chris
            • nickg
              • Jul 2007
              • 110
              • Marietta, Georgia
              Very nice work!! Something to be proud of. I especially like the way you did the bartop.
              Nick
              • prlundberg
                • May 2006
                • 183
                • Minnesota
                Looks nice, but you won't make friends with an empty bar!
                Phil
                • ragswl4
                  • 1559
                  • Winchester, Ca
                  • C-Man 22114
                  Nice and very innovative to use the Ikea cabinets as the base.
                  RAGS
                  Raggy and Me in San Felipe
                  sigpic
                    Very nice.
