Weapons Rack - cherry w/ wenge inlay
    Having finally gotten the rest of our stuff moved from our old house (which finally sold), I found that I had a good deal of weapons laying about. All martial arts weapons mind you, swords, bokken, that sort of thing, and I wanted them hung up out of the way. I also had some cherry laying around, looking for a projects, so I made this....
    There is an Asian inspired inlay of Wenge involved, as I wanted to add something, the joinery is mortise and loose tenon. This will eventually be wall mounted out of the reach of prying kids.
    The finish is seal a cell and arm r seal, now just awaiting the "time" component of a good cherry finish.
    Very nice.
    • blame
      • 196
      • Northern MO
      • delta ts-220 or something like that
      cool, great job. i like cherry but i find it burns easy if your blades are not sharp enough.
      blame
        Beautiful Keith.
        • Knottscott
          • 3815
          • Rochester, NY.
          • 2008 Shop Fox W1677
          That's cool! How'd you do the inlay?
            Very nice. How about a picture of it "loaded"?
              That looks very nice.
                Cool idea. I have a set of 'practice' swords that I need to make a rack for. Still on the plastic antlers.
                  I have to pick a place in the house to mount it, then I'll post a pic here loaded up.
                  The inlay was done in the traditional sense, designed a graphic on the computer using bezier curves, printed the pattern, mounted to some 1/8" wenge, and cut it out on the scroll saw. Then double stick taped it to the cherry, and scored the outside with a knife several times. Filled in the score lines with graphite, and routed out the inlay with an Amana inlay bit (1/16" in size). Clean up a bit with a nice sharp marples chisel, and chamfered the back of the inlay. Then glued it together. Afterwards I ran it through my drum sander a few times to level off the inlay.
                  This was a good project for me, using template routing, inlay, loose mortise and tenon, most of the skills that I've developed over the last 2 years, was glad to have the need for it, to get the chance to make something like this.
                  Thanks all,
