Clamp storage system
    I made the hangers for the 'Workbench' storage system last weekend and got them installed today. The pegboard is 38" wide, 48" high and now holds 44 clamps. The only thing not hanging on it are quick grip, spring, and pipe clamps.
  • Brian G
    • Jun 2003
    • 993
    • Bloomington, Minnesota.
    • G0899
    Nicely done. I need something better like that for my, umm, *cough* *cough*. . .well, let's just say I have a lot of clamps.
    Brian
    • Scottydont
      • 2359
      • Edmonds, WA, USA.
      • Delta Industrial Hybrid
      Looks great Pappy!
      Scott
      Edmonds WA
      No coffee, no worky!
      • ivwshane
        • 446
        • Sacramento CA
        Home depot doesn't even have that many clamps
        • gmack5
          • 1972
          • Quapaw, Oklahoma, USA.
          • Ryobi BT3000SX & BT3100
          WTG Pappy!
          Looks great, good "packaging" job. []
          George
          • RodKirby
            • 3136
            • Mao Shan TSC-10RAS
            Nice job Pappy, Warms my heart
            Downunder ... 1" = 25.4mm
            • Jim Boyd
              • 1766
              • Montgomery, Texas, USA.
              • Delta Unisaw
              Same here. I'll have to build 3 or 4 of them. More with expansion
              It does give me some good ideas!
              • monte
                ***** Windbag
                • 5242
                • Paw Paw, MI, USA.
                • GI 50-185M
                I need to do something like this. Mine are usually all over the shop. Thanks Pappy! Yours looks great!
                Monte (another darksider)
                  From the owner of the cleanest, most organized shop in the world that is a high complement!
                  For anyone wanting to build these, the plans came from the April '04 issue. I made copies at the library. I also made some notes on the positioning of the mount hloes and support arm screw pilot holes for the F-body and aluminum bar clamp holders.Scetches on a chunl of ply right now. I will draw them up and post them here.
                  The box mounted lower right holds the corner pieces for bessie Vario band clamp.
                    Very nice Pappy. Now I have another project on the list.
                    Ken
                      Ken
                        Good job Pappy. I need to build one of those and free up some space in my cabinets.
                        • Tundra_Man
                          • 1589
                          • Sioux Falls, SD, USA.
                          Good job! I'm going to join the others and state that I also need to build one.
                          Terry
                          • GPA61
                            • 712
                            • Rancho Cucamonga, CA
                            • BT 3100 & JET JWTS
                            Excellent work Pappy. I just wish I had that many clamps to
                            put away.
                            Claudio
                            • jbalders
                              • Oct 2003
                              • 298
                              • Vienna, VA, USA.
                              • BT3100 + Shopsmith
                              Nice work Pappy.. I might have to follow your lead and make something for my Bessey K-Bodies, and my really old 84" bar clamps.
                              Since we're talking finished clamp racks, I did this a few months ago to hold the multitude of my lightweight HF Pittsburg F-style clamps, as well as some others that I'd picked up off of ebay:
                              It was made with reclaimed knotty pine tongue-n-groove paneling from my basement. I gang-cut the notches using a dado blade and a step-n-repeat board (I'm sure there's a technical term for it, but it escapes me at the moment), assembled it with glue and my (then) new PC FN250 nailer, and sprayed poly on it with my HF turbine HVLP sprayer. I think there's 8 6", 8 12", 8 18", 8 24", 8 30", 4 36", 4 48" and two older 6" Irwins hanging on there.
                              There are two things I think I would have done differently. One is to make the slots slightly farther apart. It fits the clamps I got off of ebay pretty well, but I must have measuered the HF ones wrong, because it needs just a fraction of an inch more between clamps. They're currently 1" apart. I probably should have gone with 1-1/8" between the slots. The other thing is that I probably should have put a raised section on the top, near the front, so that the weight is resting on the raised section instead of on the pads. The 6" clamps don't sit in there too well. They want to rock back out of the goove because the weight is on the pad.
                              Jeff
                              Jeff
