Vanity project
  • Stan
    • 966
    • Kalispell, MT, USA.
    • BT3100, Delta 36-717
    Vanity project
    A vanity project requested by the niece/nephew. Initial design was done with Better Homes & Gardens Interior Designer 7.0. It will go 'out the door' tomorrow after I get the right offset hinge plates (just used what I had at the moment to put it together). Toe-kicks will be installed after they get it in place.
    Niece will be adding a tile countertop with a vessel sink as one of her home building projects. She will also be adding some burnished bronze drawer/door pulls.
    Hickory with 3 coats of Minwax Water based Poly Satin.
    http://www.elksigndesigns.com
  • ironhat
    • 2553
    Sweeet. What are your wood choices?
    Blessings,
    Chiz
    • bigstick509
      • 1227
      • Macomb, MI, USA.
      Very Nice
      • bthere
        • 462
        • Alpharetta, GA
        Excellent. Can't say enough about the look of the piece and the hickory grain really jumps out.
        • Stan
          • 966
          Hickory on this one (not quite as rustic as they wanted -- but that's what they found for lumber). The faux pegs are Black Walnut.
          Next few projects will be out of Rustic Alder.
            Very nice. I like it a lot. Almost a little Greene and Greene.
            Paul
              Well done, Stan....
              Regards...
                Nice work, Stan.
                  That turned out NICE! Are the corners pegged with dowels or is that decorative buttons?
                  • Stan
                    • 966
                    Punched a hole with the mortiser and drove in a 3/8 x 3/8 chunk of Black Walnut into each hole --- decorative faux pegs.
                      That is beautiful work Stan.
                      • ejs1097
                        • Mar 2005
                        • 486
                        • Pittsburgh, PA, USA.
                        Great job. I really like the door frames. They are unique and stand out.
                        Eric
                        Be Kind Online
                        • Popeye
                          • 1848
                          • Woodbine, Ga
                          • Grizzly 1023SL
                          Puuurdy, looks like you got the rattle can issue squared away after I went to bed. Nice design too. Pat
                            Excellent Stan, as usual.
                            k
                              Stan,
                              Very very nice indeed.
