Miter saw station
    Miter saw station
    This is probably my first project while following a plan. Previous projects were “off the top of my head”, and usually left something to be desired.
    I decided to replace my old miter station with one I found in a book. What I liked about it is the fact that the wings could be taken off, and stored inside the miter station. It also sported a long fence on each side, and they stored on the back of the miter station when not in use. The stop block could only go to the end of the fence, so a sliding extension was added to allow the stop block to be used as close as 6” from the blade.
    I made a few mistakes along the way, but in the end, it worked out pretty well. But I did learn a few things while making it. When it is set up, the distance from the end of one fence to the end of the other is 97”. Distance from the end of one wing to the end of the other is about 69”. When closed for storage, the unit measures about 16” X 37”.
    First pic shows the station with no wings attached.
    Second pic has one of the wings taken out of storage.
    Third pic is with wings attached.
    Fourth pic is putting a fence on one wing.
    Fifth pic shows stop block detail.
    Fifth pic shows a wing flipped over, ready to insert for storage.
    Last one shows storage of fences on back of station.
    • Anna
      • 728
      • CA, USA.
      Really cool. Just finished the basic part of my miter saw station, and your wing system gives me a pretty good idea of what I need to extend my table. It's something I've been thinking about for the last week now (with about half a dozen different variations), so thanks.
      Anna
      • MikeMcCoy
        • Nov 2004
        • 790
        • Moncks Corner, SC, USA.
        • Delta Contractor Saw
        Nice job Ed - makes good use of the space and doesn't waste "storage" space when it all isn't being used.
          Interesting idea!
          • wardprobst
            • 681
            • Wichita Falls, TX, USA.
            • Craftsman 22811
            Very nice Mr. Ed. If I may ask, are the plans available online?
            DP
            www.wardprobst.com
              Thanks for taking a look. Anna, if you have any questions about it, send me a PM. I should have noted that the plans call for cutting out a place on the wings to use as a hand hold when the wings are stored. I didn't do that, but I might yet.
                DP
                I sent you a PM.
                • warrenp
                  • 124
                  • Kentucky, USA.
                  Nice setup...looks like it will make things lots easier.
                    Wow. That is very nice Ed. Great solution - it gives you extensions but also leaves the saw portable.
                    • Stan
                      • 966
                      • Kalispell, MT, USA.
                      • BT3100, Delta 36-717
                      Great project, where are the plans available from?
                      http://www.elksigndesigns.com
                      • SHADOWFOX
                        • 1232
                        • IL, USA.
                        • DELTA 36-675
                        Very cool, Ed! Great job!
                        Chris
                        • ChrisD
                          • 881
                          • CHICAGO, IL, USA.
                          Ed, that's a nice home for a miter saw. Good job!
                          Chris
                          • Popeye
                            • 1848
                            • Woodbine, Ga
                            • Grizzly 1023SL
                            That's a pretty danged slick idea. Good going. Pat
                            • gad5264
                              • 1407
                              • Columbus, Ohio, USA
                              • BT3000/BT3100NIB
                              Nice addition to any shop.
                              Grant
                              "GO Buckeyes"
