I built this to try and sell at the local antique / flee market thingy, it didn't sell. So now its a telephone stand. Not much of a market for this kind of stuff around here, but what do I know. Walnut and soft maple with a little curly in it, wipe on poly. My first dove tails joining the legs to the apron. A little loose but, the poly glue filled it nicely. I think I should have put a little detail of some sort in the aprons. What do you think?
Plant stand
Very nice! I have a similar project in the planning stage right now, so if you'll entertain a couple questions...
Do you mean sliding dovetails joining the legs and aprons?
Did you do those on the router table?
About how big is the top?
Thanks and nice job.--Rob
sigpic -
Simple yet elegant!! They definitely missed out on this fine piece of furniture. Great work!Chris
"The first key to wisdom is constant and frequent questioning, for by doubting we are led to question and by questioning we arrive at the truth." -Pierre Abelard 11th Century philosopher.Comment
My favorite combo of woods. I think you did a fine job, sorry to hear that it didn't sell. I had some similar thoughts of trying to sell such a table, but havn't even had time to build one. You did great.Keith Z. Leonard
Go Steelers!Comment
I like it just the way it is.Larry R. Rogers
http://community.webshots.com/user/splash54Comment
Thanks for the kind words.
Yes, I guess they are sliding dovetails, similar to mortise and tennon. I figured since some one might put a tree on it, and dirt is pretty heavy, the dovetail would be a little stronger joint. I did them all on the router table just moving the fence, sneaking up on the right fit. I don't know if that’s the correct way since some were tight and others not so much. I also ran the pieces through between the fence and bit, I think that contributed to the looseness, not to mention dangerous.
I made the top 14” square. I used a trash can to model the size.
Also the center panel is floating on splines, Thanks to Gmack’s advice.M. Leichtle
Beer is proof that God exsists and wants us to be happy.
Ben FranklinComment
