Finished ahead of schedule!
  • kwgeorge
    • 1419
    • Alvin, TX, USA.
    Well I am finished with the table, well almost anyway I still have to attach the hardware latch that locks the table top in the up position but it has not got here yet so I will do that as soon and it makes it here. I have to tell you that this is the hardest project I have done to date and by far the most complex. I was originally inspired to do this table by seeing late 1700’s versions of it at a higher end antique show the wife and I attended. For better or worse the design is my own and I only received inspiration and ideas from the probably 100 or so I have looked at since I decided to make this. I found many challenges in making this table and was able to conquer each one well maybe not the best way but I got it done. I made everything on this table including the hard maple dowels. The only thing I did not make was the screws that attach the cleats and the soon to be attached lock hardware.
    The table is 25” tall and the top is 23-1/2” across. This is the reason I started turning in the first place was to be able to do a piece like this. I am just a bit proud of it right now so forgive me if I blather on. As you can see in this picture of the side view the birds nest is attached to the spindle with a Bubinga wedge. I purposely offset the pivot dowels so the table would sit 1/8” higher. My reason in doing this was to install little rubber bumpers so that the underside of the top does not get damaged.
    Here is a picture of the table top in the down position. The Bubinga veneer has a massive 3-D quality to it and it looks as though you could reach right in it. When making the top I used some veneer that the edges were very cracked and damaged so I ended up slip matching the veneer as I thought that may look interesting with the segmented lip anyway.
    Here is a view of the table in the down position from the back. As you can see I also used Bubinga veneer on the back of this table. If you look to the bottom you will notice knots in the veneer. I had to do quite a bit of repair to this veneer to use it but it was certainly not A grade but I thought it had potential.
    Here is a view of the table from the bottom. This shows how the sliding dovetails came out after I spent some time flattening the legs to the spindle.
    I finished this one quicker than I expected but that’s what happens when you are so into it that you wake up in the middle of the night to apply another finish coat! As I said before I am quite camera challenged but I did my best with the pictures for now. I want to thanks the ones who stuck with me through the building of this table as I had never posted like that before but I thought it would be fun.
    Comments and thoughts welcome and thanks for taking the time to look.
    Ken
  • lcm1947
    • 1490
    • Austin, Texas
    • BT 3100-1
    That is a work of art Ken. It is simply breath taking. I love that color and finish. You did more then good!
    • Ken Weaver
      • 2417
      • Clemson, SC, USA
      • Rigid TS3650
      Ken that is absolutely awesome!!! You have every right to be proud. Really beautiful work and that veneer is breath taking!
      Ken Weaver
      Clemson, SC
        So when are you going to start to blather on and brag a bit? Nothing you have said so far comes off as bragging when one is looking at a piece of furniture of this quality!
        • MilDoc
          Very nice! I love the top!
          • DonHo
            • 1098
            • Shawnee, OK, USA.
            It's beautiful but no suprise, I've come to expect nothing but outstanding work from you. The top is wonderful.
            DonHo
            Don
            • gerti
              • 2233
              • Minnetonka, MN, USA.
              • BT3100 "Frankensaw"
              Ken,
              You got every right to be proud! Beautiful piece, great design!
                • 8803
                Beautifully done! The Top does have a 3-D effect. Even on my screen, I can see it. I don't know if you have tried this, or if you can do it on your computer screen (or in real life) but looking at the top (second picture), with eyes slightly crossed as in looking at 3D photos, you can see a depth in layers, kind of like it was computer generated.
                • RodKirby
                  • 3136
                  • Mao Shan TSC-10RAS
                  Superb design - beautifully executed
                  WAY out of my league
                  Downunder ... 1" = 25.4mm
                  • dale
                    • 147
                    • Mesa, AZ, USA.
                    • BTS-15
                    Not only is it beautiful, but a Magic-Eye table top is just cool!
                    I really am going to make something one of these days.
                      Ken
                      The table is a real example of craftsmanship. I can't even imagine the time and planning that went into this project. The different woods really give the piece its individuality. The fit and finish makes all the effort worthwhile. I like the joint work and the turnings too. I love reproduction pieces, but it's like someone else said somewhere, "I don't have another lifetime".
                      • boblon
                        • 727
                        • Florida, USA.
                        Absolutely beautiful !!
                        BobL.
                          Ooooo. Aaaaaah!
                          Beutiful! The dovetailed leges are very nicely done.
                          Congratulations.
                            Ken that is absolutely beautiful. I wish I had your talent. You are truly blessed.
                              Beautiful work Ken, as all of your projects are.
