Cutting Board
  • LYU370
    • Mar 2005
    • 215
    • Streamwood, IL.
    Cutting Board
    This is probably the fourth or fifth one I've made so far. I finally remembered to take a few pics before I gave it away. Mostly Maple, with a bit of Walnut and Cherry.
    Andy
  • GeekMom
    • 752
    • Bonney Lake, WA.
    • Shopsmith Mark V
    Nice! I like the random design.
    Karen
    • charliex
      • 632
      • Spring Valley, MN, USA.
      • Sears equivelent BT3100-1
      Okay! Another useful project that's too nice to use. You want to cut WHAT and with a KNIFE on my art-work cutting board. I don't think so..
      Really is a nice looking board. Keep up the good work.
      • djcannon
        • 27
        • Kennewick, WA
        Using a nice bord
        That is a great looking board I needed some projects to use my scrap wood on and this is a great idea.
        I made a similar board in High school for my mother, it was round designed for cutting pizza's. She only cuts on one side leaving the other unharmed it has worked well and has been used almost weekly for over 10 years. If the cutting side is up it looks very used, if it is down it looks like new. The only reason this has worked is I made it so both sides are identicle.
          very nice, I like the layout.
          • TheRic
            • Jun 2004
            • 1912
            • West Central Ohio
            Been thinking about making butcher-block style items. What type of glue do you use? What type of finish, or is it bare wood?? Is the glue and/or finish safe for all kinds of food? What kind of maintenance / upkeep is required? Are the pieces flat sides just glued together, or some kind of joint? Would this same technique work on larger pieces like end tables, workbench, tabletop, etc.
            Thanks for any and all help.
            Ric
            • SHADOWFOX
              • 1232
              • IL, USA.
              • DELTA 36-675
              Gorgeous looking board!! Very nice work.
              Chris
                Great cutting board, Andy. I see some repeat patterns, but I can't tell how many edge glue ups were used.
                  That is nice. I have been thinking about making one of them. I hope mine turns out as nice as yours.
                  • LYU370
                    • Mar 2005
                    • 215
                    • Streamwood, IL.
                    Thanks. This one was one of a batch of three that I made, I think I had about 12-14 different edge glue ups that I used. Don't recall if this one used all of them or not.
                    Andy
                      Great looking board. You should open a business. Looks like a giant Rubik's Cube for woodworkers.
                      • LYU370
                        • Mar 2005
                        • 215
                        • Streamwood, IL.
                        Used Titebond III, waterproof, foodsafe, little longer open time. Finish is just plain old mineral oil, also foodsafe. Don't use vegetable, olive, corn oils and such as they can go rancid over time. You can also use a salad bowl finish. Also heard that you can use nut oils, but those are more expensive so I just keep it simple and use plain mineral oil. Maintenance is just some additional mineral oil every now and then. All the pieces were just edge glued then planed flat, cut into strips then glued up again.
                        Andy
                        • LYU370
                          • Mar 2005
                          • 215
                          • Streamwood, IL.
                          That's too funny. I made one for a friend as a Christmas present and she refuses to use it for that reason.
                          Andy
                            I like it! All those glue ups must have driven you batty.
                            • Wood_workur
                              • 1914
                              • Ohio
                              • Ryobi bt3100-1
                              looks like somebody robbedthe museum of fine art...
                              Just kidding. You did a wonderful job, espically with the feet (A nice detail).
                              Alex
