Well I am at it again;
  • kwgeorge
    • 1419
    • Alvin, TX, USA.
    I bet you guys will be glad when I get through this tool making kick that I am currently on. It really is a lot of fun though as I can mix metal work, turning and flat work all into one form.
    The first thing I made I really made last weekend during a break I had from working on my son’s truck. It is an Awl made from Canary Wood, Plumbing nut and a salvaged spade bit. I tried to make it comfortable and functional as well as esthetically pleasing. The shape I came up with is based on antique door knobs that were in my grandmother’s house. I did not post this last weekend due to the forum issues.
    Last weekend I also got to go to Woodcraft for some things. While there I noticed that they had there Wheel Marking Gauge on sale for $9.49 but as luck would have it they were out. So I decided that I would make my own but I have to tell you that I have enough hours into this thing that if I were to compete with the $10 at Woodcraft I would be making like 50 cents an hour! Oh well, I tried to make just about everything on this myself. The cutter I made from an old Recipicating saw blade that I had. I turned it round with a carbide cutter on the metal lathe and sharpened it with diamond hones. I still need to modify a 10-24 screw to finish making the cutter and rod flush with the surface. I decided to use 3/8” drill rod for the rod as it would have less tendency to flex as the normal 1/4” would.
    I was going to mill a flat section on the drill rod but this thing locks so tight it was not necessary. Although I may later and add a ruler to it. The wood I chose is called “Desert Eucalyptus” Maybe because it looks very much like Eucalyptus but is like ten times harder! I shaped the main body somewhat like a bell but really it just fit my hand well like this. The locking nut I made on the metal lathe and then inlayed wood into it.
    I made the nut a bit high but threaded it all the way up incase I decided to cut it down lower later. I have not decided on that yet and think I will use it a couple of times first.
    Thanks for having a look at my madness.
  • thestinker
    • Oct 2005
    • 613
    • Fort Worth, TX, USA.
    Wow !!!! Some nice looking tools there man!!
      Very nice! Love tools that are more than just something to do the job, they are a piece of art.
        beautiful work, as always, Ken!
        • lcm1947
          • 1490
          • Austin, Texas
          • BT 3100-1
          WOW! those are just unbelieveable.
            Beautiful workmanship, Ken
            ken
            • Copper
              • 343
              • Madison, WI.
              Awwwl, those are beautiful!
              - Dennis
              "If your mind goes blank, don't forget to turn off the sound." --Red Green
              and yes, it's a potato.
                Definetly up to the high standard you've set with the rest of your tools.
                • boblon
                  • 727
                  • Florida, USA.
                  Those look great Ken. I especially like the knob on that marking gauge. Excellent detail.
                  BTW, I for one am getting now where near tired of looking at the beautiful tools you are producing.
                  BobL.
                  • scmhogg
                    • 1839
                    • Simi Valley, CA, USA.
                    Ken,
                    Beautiful tools!! You could compete with Bridge City.
                    Steve
                    • monte
                      ***** Windbag
                      • 5242
                      • Paw Paw, MI, USA.
                      • GI 50-185M
                      Very ice work Ken.
                      Monte (another darksider)
                      • Never2old2start
                        • Oct 2005
                        • 112
                        • Orlando, Florida, USA.
                        Good Grief! What craftsmanship!~ Ken, you are good!!!
                        ~ Paul ~
