Portable outfeed table made with 80/20
  • MoldnMaker
    • 146
    • McKenzie, TN, USA.
    My last Thread got corrupted by the DB problem, so I kindly asked Sam to remove it. Now I'm reposting this thread.
    For those who didn't read the first one, here is a summary:
    What- Portable out feed table made with 80/20 extruded aluminum profiles.
    Specs - Top : red oak 24 1/2" x 11" (attached to rails with t-nuts)
    Frame: aluminum profiles that attach to the rear rail w/ t-nuts )
    Legs: HWM w/ leveling feet
    Features:
    • can be moved anywhere along rear rail
    • can be made wide or narrow
    • level with height of the main saw table
    • easily replaceable top
    options: SMT adapter**
    **( not made yet, but have mock up pic, the mahogany board in the pic represents the SMT and the cardboard represents the adapter. The adapter is secured with a profile attached to the center of the top and the right side rail via t-nuts)
    Thanks to everyone that responded to the other post your feedback is much appreciated.
    UPDATE- I added some finishing touches to it like a wipe down with Old English red oil, a stretcher between the legs ( adjustable ), wooden end caps, and rubber pads on the ends touching the rear rail. Once mounted and adjusted it can be put on or removed in less than a minute. Here are some updated picks with it attached to saw :
    "Reality is merely an illusion, albeit a very persistent one." by Albert Einstein
  • RodKirby
    • 3136
    • Mao Shan TSC-10RAS
    Looks good, but...
    I would feel more comfortable with a stretcher, half way down the legs.
    Downunder ... 1" = 25.4mm
    • MoldnMaker
      • 146
      Suggestion noted and done. Another quick fix (another profile mounted to legs with t-nuts, so stretcher can be adjusted to size of table.) Thanks.
      • MoldnMaker
        • 146
        Updated Post And Pics.
