Hello, so I just received my switch yesterday. I went in to replace it and I just want to be sure I'm doing it right before I ruin something, which I am prone to do. Know where I can find how to replace the switch or can anyone provide any feedback? Thanks in advance!
BT3000 Switch Replacement
Tags: None
If you haven’t installed the switch I may have instructions from ryobi. If you still need it I will try to check my binder or files for the instructions.
Lee -
I did end up figuring it out, I should have posted on here that I did .Thank you for trying to help .it was easier than I thought, I just didn't want to blow the motor for wiring it wrong .someone told me that the saw wouldn't run if it was wired wrong, so I shouldn't worry about blowing the motor .Comment
I also would like to replace my switch on my Ryobi BT 3000 table saw. What switch/model did you use. Thanx. JimComment
