BT3000 : Bevel lock issue
  • sscherin
    • 772
    • Kennewick, WA, USA.
    My Bt3000 has started having a problem with the bevel lock.
    After adjusting the blade to the desired angle moving the lock lever back to the raise position causes the blade to change angles.
    Is this just a maintenance/cleaning issue?
    William's Law--
    Seems some slippage is normal, others recently discussed similar experiences, discussed here:
    http://www.bt3central.com/showthread...ighlight=bevel
