Hi I was wondering if any one could tell me what the size of this table was/is? Regards Bob
Air floataion table
Tags: None
I don't have flotation table but I know it is supposed to fit between rails on BT3100 and distance between rails is 22.5". So table width should be just short of 22.5" to fit. You can probably use your accesory table on BT3100 as a guide - width should be same.Last edited by vaking; 08-26-2011, 01:10 PM.Alex VComment
Air floatation table
Thanks Alex. I am in the process of building acabinet for my BT 3000 and have the wide table rails but not the table. Regards Bob McdermidComment
Have you located a flotation table? I don't see them available all that often anymore. I think they were pretty heavy. That might have been the fold down outfeed table though. A few times I saw offerings the seller didn't want to try to ship it.
I've used some Phenolic coated ply from Woodcraft for my router table insert. It is a pretty slick surface and even slicker when waxed. http://www.woodcraft.com/Product/200...x-24-x-48.aspxErikComment
