Hi Gurus,
With the help of the forum, I fixed the bent clamper (#23) and also replaced plastic plate (#27). But still the rip fence has some issues.
In the open position, the lip of the rear Clamper-B is close to the rear rail, as can be seen in this picture.
When I push down the rip fence handle to lock it down, I can get the handle to the 2'o clock position and it is quite stiff at this point. However, as you can see in the picture, the lip of the rear Clamper-B is just touching the lip of the rear fence. The clamper is NOT fully locking into the rear fence channels, as one would expect. I have also attached the underside picture of the fence handle. I also tried to first pull the the rear clamper into the rear rail lip and then tried to align the front rail with the fence but that put the front of the fence totally out of the rails and I couldn't bring the fence to align with the rails.
What could be going wrong here?
