Greetings, all
Trying to get my bt3000 aligned; sailor's problems inspired me after I had long given up and looked for other answers. So far, I've taken these steps...
1. Take the saw off the stand and level it. Clean sawdust out of saw and re-mount it on the stand.
2. Test and confirm that my right angle is square. Try square, protractor, and pencil and paper test; everything agrees it is.
3. Following manual, align rails. Check and triple check.
4. Rebuild sliding miter table using directions found here. It slides easier then before and doesn't wiggle; thanks to whoever did such a nice job with the write-up.
5. Set miter fence to the 90 degrees on smt. Align smt to 90 degrees to blade. Taking care - as always - not to hit teeth
6. Make a test cut, using clamp to make sure board doesn't move. Inspect cut; half degree out of alignment still.
7. Recheck rails. Recheck smt. Set fence to half degree off. Make test cust. Inspect cut; now 90 degrees.
8. Use square to test fence to blade angle. It is going to only hit the front of the blade. Based on the angle of the square, I'd expect it's about a half degree off. Take time to try and figure out how the cut comes up 90 degrees. No answers.
9. Realign fence. Hold wood against fence and move slowly past stationary blade. Doesn't drift away so I think the rails are good.
10. Decide to write and see if any of the BT3000 experts have answers.
Thanks for the coffee break; I've got to go back and see if the fool thing actually wants to cooperate. In the meantime, anyone got any theories?
