I have owned my BT3000 for 10+ yrs. Best saw I've owned. I wonder if anyone has ever found a better rip fence that would be adaptable to this table? Mine is well worn! I'm getting a new one, but want to see if there's one that's better? Thanks
Living overseas, I bought a couple of extra parts for mine and have them on hand in case I need them. Parts can still be purchased through Sears parts, I think.
A second option is to look for a sale on a BT here (on this forum or craiglist/ebay) that is being parted out - i.e. being sold as parts.
A note on the fence - there was one replacement fence offered at one time but no one on either of the two BT3000/3100 support forums had one that I remember. The reason was - the BT fence has always been a great fence in that it would lock into position on both ends and was very accurate once set up. This is for people who took good care of their saw. This saw as not a good saw for ham fisted using but good for the person that took great care.
For a larger fence, I made a sacrificial fence in an "H" shape. I made it so that it would slip very snugly on top of the BT's fence. Worked well and still is after 8 years.
Mike, thak you and that site is great. Ya know it's funny, you look at the cost of that upgrade system and all things being equal, a BT3000 would probably be %600 - $700 (saw alone). Their setup wouldhave made this saw a $2,000 saw today!
Again welcome to the site! And thus the warning! For that amount of money I could buy a cabinet or hybrid saw with a different set of problems.
Sorry, I don't have a photo but it is easier to make than describe.
1. I cut a 2x2 down the the exact/precise width of the fence and cut it to the length of the aluminum section of the fence.
2. I cut 2 pieces of 3/4 plywood into 4 inch by 36 inches long.
3. I placed the 2X2 on top of the fence, placed the 36 inch strip on each side against the fence and glued and screwed it together. I made sure that the screws were about 1/4 inch recessed into the fence on both sides.
4. Upon screwing the sides onto it, I removed it from the fence and cleaned excess glue off.
In the end it looked like an "H" in which the bottom channel of the "H" slides over the fence.
