The rip fence on my BT3000 only works when it is set to tighten by pulling up on the handle. If you push the handle all the way down it will release both the back and front locking mechanisms. If you pull the handle all the way up it locks in place and you can’t move it with a semi.
I know, I know there are lots of threads about adjusting the rip fence. I have read most of them, in fact Ion the advice of the threads I added an extra long 10x24 bolt to the back clamp, removed and straightened the front clamp, and re aligned the bolt in the back clamp. Other than disassembling and reassembling the “@#$##%??&*” thing 6 times tonight it works just fine, just backwards. The only problem with this method is the handle interferes with the straight edge of the fence.
So after all of that it appears the roll pin on the rod was hanging up on the insides of the fence. I ground about a 1/8 inch off of each side, and finally got the fence to work correctly. What an enjoyable night
